Is my left turn signal switch bad??? - Road Glide Forums
  • 1 Post By MightyWhitey
post #1 of 8 (permalink) Old 09-21-2017, 08:31 PM Thread Starter
Hey guys. The other day, I was coming home and my left turn sig just started coming on and off uncommanded. Haven't ridden since but noticed when you turn the ignition on, the left turn sig is in immediately and turned off when hitting the right turn sig. I don't have a meter to test it but is it safe to say it's probably the switch ? I mean, everything else works as is, the bulbs are good.. would it do this if the plug was loose in the fairing? I'm doubting that as it probably wouldn't work at all. I found a replacement switch from jp cycles for 20 and getting ready to just grab it and replace it.
Seems like a fairly simple task just splicing in the new wires and swapping switches.
This is a 12 road glide custom by the way.
Any input would be really appreciated! Thanks
Dyna-petey is offline
post #2 of 8 (permalink) Old 09-21-2017, 08:44 PM
lil chief's Avatar
It's a good possibility the switch is bad, or the wiring at the switch got frayed and it's touching both terminals, creating a constant on. Maybe pull it apart first and see if there's anything obvious in that switch housing before ordering a new one. Maybe it has some corrosion in it which is also keeping it in the constant on position. Once you get it out of the housing, carefully pop the plastic cover off the switch itself. If no wiring is messed up, shoot it with some electrical contact cleaner ans see if that does the trick.
Lil Chief
lil chief is offline
post #3 of 8 (permalink) Old 09-22-2017, 07:34 AM
MightyWhitey's Avatar
How many times has the fairing been off? Might have a pinched wire grounding.
Swomack likes this.
MightyWhitey is offline
post #4 of 8 (permalink) Old 09-22-2017, 07:56 AM
rideon's Avatar
Have the bars been changed recently? I would agree with the other guys, have a poke around first, look for pinched wires.
2018 Road Glide Special, vivid black
rideon is offline
post #5 of 8 (permalink) Old 09-22-2017, 08:16 AM
Swomack's Avatar
Sounds like a pinched wire to me as well.
Let us know what you find out brother.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #6 of 8 (permalink) Old 09-22-2017, 11:26 AM Thread Starter
thanks guys.. i will look around .. i had the fairing off 2 months ago swapping bars.. but never had an issue until now.
post #7 of 8 (permalink) Old 09-22-2017, 07:41 PM
Sometimes these things surface for their down the road. Take your fairing off, turn the key on and move the wires around. Have you tried turning the key on and turning your bars right and left a bunch? Good luck with your search.
post #8 of 8 (permalink) Old 09-22-2017, 09:31 PM
bucketlisthd's Avatar
It's real easy to pinch the turn signal wires on a pre Rushmore fairing. That's a good place to start.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
Left turn signal will not work justaguy Controls & Handlebars 6 12-31-2013 12:41 AM
Pinched wires, front left signal HellInABucket *General Road Glide Discussions/Pictures 12 06-13-2013 11:21 PM
Going left..... Way left! DarbinCo Troubleshooting for Road Glides 13 09-20-2012 11:16 PM
Left turn signal richrabb *General Road Glide Discussions/Pictures 3 12-14-2011 08:45 AM
left turn signal rdbateman Troubleshooting for Road Glides 14 06-22-2011 06:45 PM
