Hi/Low beam at same time on Rushmore? - Road Glide Forums
post #1 of 6 (permalink) Old 09-27-2017, 12:52 PM Thread Starter
wheredugo's Avatar
Has anyone figured out a way to turn on the hi and low beam at the same time ? Is there a harness available? or some way to do it thru the canbus system ?
wheredugo is offline
post #2 of 6 (permalink) Old 09-27-2017, 02:21 PM
Hmm... On my 2015, both low and high stay on at the same time when I have the high beams on. Came that way from factory. I see the same on other Road Glides around here. That is odd. Perhaps have it checked out if still under warranty.
2015 Road Glide Special
caberto is offline
post #3 of 6 (permalink) Old 09-27-2017, 02:33 PM
twowheeladdict's Avatar
I just walked out to the garage and confirmed that the low beam stays on all the time. Whether the high beam is on or not.
twowheeladdict is offline
post #4 of 6 (permalink) Old 09-27-2017, 03:42 PM Thread Starter
wheredugo's Avatar
Ok maybe im just an idiot and assumed one shut off. Disregard post ! Im sorry ! I thought the low beam shut off when the high beam fired.
post #5 of 6 (permalink) Old 09-27-2017, 03:45 PM
UT_Larry's Avatar
If low is turning off with high beam on it's not functioning correctly. I recall a previous thread & headlight was replaced under warranty.
UT_Larry is offline
post #6 of 6 (permalink) Old 09-27-2017, 05:33 PM
Did you actually look at the headlights? No problems man. We are here to help.
Low/High beam testing sanity check? Driftah Lighting 2 07-17-2013 06:18 PM
Rewiring Bright/Low switch so you can hit brites and horn at same time DC-3Mek Do-IT-Yourself 39 06-02-2013 05:57 PM
Daymaker light pictures (low Beam) txflyer Lighting 8 05-28-2013 11:18 PM
HID High Beam Low Beam Fit EasternSP Lighting 9 09-29-2012 01:05 AM
