Led Brake light issue is baffling - Road Glide Forums
post #1 of 1 (permalink) Old 04-04-2018, 11:36 PM Thread Starter
Hammy 13RGU's Avatar
So I have a 2013 Road Glide Ultra. I put a CVO style Nasty Hog fender on it. These have LED lights and lights worked great. I Added a light bar (run brake) on the tour pack. The issue is once the light bar was added the lights on tour pack work fine, Brake and run but on the fender turn and run lights work fine but no brake lights. That is the situation when the ignition switch is set to run. However, when I switch the ignition switch to accessories the brake lights on fender will come on perfectly if I depress brake lever(s). it's Got me baffled! I was thinking that maybe I need a load modulator?? but all I read says they are mostly for turn signal issues. Looking for thoughts for me to troubleshoot.
Hammy 13RGU is offline
Turn signals and brake light LED install billd76 Lighting 3 09-21-2015 04:49 PM
For Sale: Chopped TourPak w/ Wing Led Brake Light nking262 Parts for Sale 22 05-13-2015 05:12 AM
LED Brake Light antant Lighting 0 02-02-2015 03:58 PM
Brake light, Cruise issue Joker659 Troubleshooting for Road Glides 14 04-24-2012 01:13 PM
LED Turn/Brake Light Strips in Filler Panel gbourdon Lighting 8 01-10-2012 03:18 PM
