ACC Power Wire - Road Glide Forums
post #1 of 5 (permalink) Old 04-20-2018, 01:38 PM Thread Starter
ACC Power Wire
Where is a good place (under the seat) to tap for ignition power? What color wire should I look for? I'm using a Posi-tap and don't want to connect wire directly to the battery positive terminal. BTW, I own an electrical manual but lend it out and don't have it in hand right now. It's a 2015 RGS. Thanks in advance.
AndyFL is offline
post #2 of 5 (permalink) Old 04-20-2018, 02:26 PM
lastride's Avatar
Under the left side cover is a gray plug that has what your looking for. You can get a plug in harness from HD.
lastride is offline
post #3 of 5 (permalink) Old 04-20-2018, 03:06 PM Thread Starter
Last ride, you happen to know which wire is powered by the ignition in there? I'm using a Posi-tap to hook up my positive with such wire, not wanting to go the HD harness route. Thanks.
AndyFL is offline
post #4 of 5 (permalink) Old 04-20-2018, 04:21 PM
lastride's Avatar
Not off hand, check it with a test light.
lastride is offline
post #5 of 5 (permalink) Old 04-20-2018, 09:43 PM Thread Starter
Anyone else looking for the hot ignition wire, I was able to pinpoint it with the help of the electrical manual. It's located behind the left side panel, the last plug (grey) nearest to the ground. Look for the red and yellow wire, that's the ACC.
AndyFL is offline
The ACC Wire Hirshberg Do-IT-Yourself 7 09-15-2014 08:28 PM
The button next to cruise (ACC) where's the power.. CHI_TOWN Equipment-RG 8 04-30-2013 08:35 PM
Acc Wire Hirshberg Do-IT-Yourself 3 12-10-2012 03:31 PM
Tour-Pak 12V acc outlet Runamuck Aftermarket Accessories 2 01-02-2011 04:46 PM
Advance Carbon Composits (ACC) Helmet Recall MarAgt *General Road Glide Discussions/Pictures 2 04-05-2010 08:18 AM
