Brake light works, running light doesn't - Road Glide Forums
post #1 of 10 (permalink) Old 06-12-2013, 12:50 AM Thread Starter
FireGuy88's Avatar
I tried to search for this but didn't come up with anything. First off, bike is a 2006. My running light is out, but my brake light works fine. I assume its the same bulb for both right? My turn signals are not duel purpose as running lights, so I need to get this fixed. Any way, could a simple bulb replacement fix the problem or could there be same underlying issue? Wiring or something?
Thanks
FireGuy88 is offline
post #2 of 10 (permalink) Old 06-12-2013, 05:00 AM
Ohiobellboy's Avatar
Check the fuses. I had pinched a wiring putting my fairing back on and blew the running light fuse before. Might just be a fuse.
A.K.A OBB
Ohiobellboy is offline
post #3 of 10 (permalink) Old 06-12-2013, 08:52 AM
yes it could be as simple as the bulb. Your front signals should also be running lights which should be on the same fuse if they are working as running lights it would appear to be a rear problem. Start simple with a new bulb and fuse check then look for wiring problems if no voltage to rear .
Eagle
Eagle is offline
post #4 of 10 (permalink) Old 06-12-2013, 10:20 AM
it's an 1157, get good one
reds4 is offline
post #5 of 10 (permalink) Old 06-12-2013, 11:49 AM Thread Starter
FireGuy88's Avatar
Well it was the fuse. Glad it was something simple. Now I'm worried why the fuse blew. Could be that its 7 years old.
post #6 of 10 (permalink) Old 06-12-2013, 12:00 PM
doubt they even know or care
reds4 is offline
post #7 of 10 (permalink) Old 06-12-2013, 12:14 PM
NORSEMAN's Avatar
The most obvious reason for a blown running light fuse would be a pinched wire that shorted. The most obvious area for a pinched wire is where the front signal light wires run from the light housing into the fairing. Yes, I know this from experience. A bulb usually blows into an open circuit condition, but I have had one blow and the filament short to ground.
2016 SGS CVO
NORSEMAN is offline
post #8 of 10 (permalink) Old 06-12-2013, 03:41 PM
no tail lights?
CHECK OUT THIS THREAD ON PAGE 2
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #9 of 10 (permalink) Old 06-12-2013, 06:40 PM
ammojeff's Avatar
Always put dielectric grease on the bulb / socket. A bit of corrosion can ruin you day. Helps when your riding in torrential down pours too!
AMMO: Giving the enemy the opportunity to die for their country
ammojeff is offline
post #10 of 10 (permalink) Old 06-12-2013, 10:41 PM Thread Starter
FireGuy88's Avatar
Originally Posted by CPY84 View Post
no tail lights?
The link didn't work apparently.
Brake like doesn't work dinggus Lighting 13 06-09-2017 09:28 AM
Starts but doesn't stay running Guero ECM/Fuel Management systems 3 12-24-2015 01:38 AM
Auxiliary Brake Light/Running Light/Turn Signal Conversion Kit-69462-06A Subvet Parts for Sale 1 12-06-2015 06:40 AM
Just wondering who running radial tires and who is running bias. Pros and cons please scsharp2260 Wheels and Tires 8 08-11-2013 07:20 AM
Fairing pocket doesn't line up :( wydeglyde Troubleshooting for Road Glides 2 04-22-2010 06:01 PM
