2013 Road Glide Custom - Road Glide Forums
post #1 of 4 (permalink) Old 10-17-2018, 09:00 PM Thread Starter
I'm having an issue with my left rear turn signal. It doesn't work in turn signal, running or brake light but it works with the security system. When I pull the lighting relay or fuse it works but is dim. I cannot figure this damn thing out. Any help or ideas would be appreciated
Chrome Goat is offline
post #2 of 4 (permalink) Old 10-17-2018, 09:40 PM
FDR's RGC's Avatar
I'd try changing the bulb.
FDR's RGC is offline
post #3 of 4 (permalink) Old 10-18-2018, 06:29 AM
Dragon Dude's Avatar
I'm wondering if you might have a weak ground problem or just a bad ground causing the issue.
Dragon Dude is offline
post #4 of 4 (permalink) Old 10-18-2018, 11:07 AM
Try taking the bulb out and looking at the 2 little pads inside the socket. Sometimes one of them will get turned or out of place. Also, I’ve seen the bulb pushed down in the slots for the socket to spring on, and not the 2 grooves for the little tits on the side of the bulb. I’ve also seen the bulb put in 180 degrees out and not work correctly.
2018 FLTRXS Wicked Red
Harley Master Tech at Hampton Roads Harley in Yorktown, VA
crazy4ink is offline
2011 Road Glide Custom Vs 2016 Road Glide Special Dant52 *General Road Glide Discussions/Pictures 4 05-05-2016 06:33 PM
2013 road glide custom/street glide wheels and tires abs JPROADGLIDE Parts for Sale 6 04-17-2014 08:55 AM
2013 Road Glide Custom - Road to glory LeotheThird Road Glide Builds-Document your builds HERE --NEW 34 04-02-2014 12:12 PM
trade 2011 road glide custom for 2012-13 CVO road glide durtybiker Bikes for Sale 0 09-24-2013 09:25 PM
Iowa Road Glide Custom Custom lowdog Road Glide Builds-Document your builds HERE --NEW 71 05-01-2013 08:23 PM
