Fairing mounted HD bullet fog lights - Page 2 - Road Glide Forums
 11Likes
post #11 of 17 (permalink) Old 03-25-2019, 04:07 PM
I purchased the fog lights, the mounts for the fairing, switch for in dash. installed it all.....yes drilled a hole in my fairing myself....wired as per instructions and nothing. Lights dont come on - checked high low beam still nothing. I haven't started the bike yet as did an intake and exhaust change at same time, and have to tune for changes. does the bike have to be running for them to work? any help would be appreciated.
Mike Dillon is offline
post #12 of 17 (permalink) Old 03-25-2019, 04:23 PM
JakeC7R's Avatar
I believe you will need the dealer to activate so they work with the switch. When you do, ask them to program so that they work on high beams or low beams. When they did mine they only worked on low and I took it back and they reprogrammed to work on either.
JakeC7R is offline
post #13 of 17 (permalink) Old 03-25-2019, 04:25 PM
BH#103's Avatar
Just the ignition has to be on or the bike running for them to work. Does the switch pack in the dash have the fog light button and also what year bike you got?
Dark Glide #2
2015 Denim Black FLTRX
D&D FatCat & FP3
BH#103 is online now
post #14 of 17 (permalink) Old 03-28-2019, 04:16 PM
Thanks. I was told about the high beam program, but I thought the lights would come on without having to be programmed.
post #15 of 17 (permalink) Old 03-28-2019, 04:18 PM
I had to buy the fog light switch for my bike. 2018 RG Special. No-one at HD indicated I would need the bike programmed to make switch work??
post #16 of 17 (permalink) Old 04-04-2019, 01:19 PM
Hilarious's Avatar
I bought the (3) switch pack that is plug and play and it works just fine with my added driving lights no programming needed. I have an ultra though and the wiring may be a little different and I am using aftermarket lights as well. I know on my bike, the switch packs activate the accessory plug under the left side cover under the seat.
Hilarious is offline
post #17 of 17 (permalink) Old 04-05-2019, 11:08 AM
I had bought the 3 switch pack at first....but the switch for the lights was a dummy button, it wasnt actually a switch. the other two were switches but had no indicators on front
Fork mounted lights for RG? ace1usmc Lighting 28 03-28-2016 09:03 PM
Roadglide fairing removal Tackdriver Paint & Bodywork Section 10 04-23-2014 09:51 PM
Can I upgrade 02 to 04 and up fairing support brackets and bullet turn signals? chevjerico *General Road Glide Discussions/Pictures 14 12-08-2013 09:05 AM
Tour Glide fairing questions Monkeyman *General Road Glide Discussions/Pictures 11 12-07-2011 04:28 AM
Fairing Removal - Lesson Learned OldNerdGuy *General Road Glide Discussions/Pictures 12 12-03-2011 06:21 PM
