2017 and newer RGU dash panel question - Road Glide Forums
  • 1 Post By Dagwood08
post #1 of 8 (permalink) Old 05-02-2019, 07:15 PM Thread Starter
BH#103's Avatar
Can any of you with a newer Ultra tell me if the left side of the dash panel where the 3 dummy looking buttons are on each side actually has the switch assembly installed on the left? Other Ultra and Limited models have the left button of the left side dummy button trio reserved and used for the auxillary lighting. My thought is without looking that the RGU's have it as well, just with 3 dummy buttons installed. Anyone?
"SLIVER"
BH#103 is offline
post #2 of 8 (permalink) Old 05-02-2019, 07:29 PM
Hopalong48's Avatar
My 15 RGS just had dummy buttons, I had to buy the recpticle and switch from HD the wiring harness was there ready to plug in.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Hopalong48 is offline
post #3 of 8 (permalink) Old 05-02-2019, 07:39 PM Thread Starter
BH#103's Avatar
Appreciate the input, but looking more for info on the '17 and newer RGU's.
"SLIVER"
BH#103 is offline
post #4 of 8 (permalink) Old 05-02-2019, 08:12 PM
HellInABucket's Avatar
These are blanks. I've owned a 17 and 18 FLTRU, same.
HellInABucket is online now
post #5 of 8 (permalink) Old 05-02-2019, 08:14 PM
Thermodyne's Avatar
18 just has blanks. There is a harness connector there, bit its almost worthless. 2 amp max load and what every you hook in has to be compatible with the BCM.
To actually run anything from the ad on switch pack, you have to add a harness and a relay.
Thermodyne is offline
post #6 of 8 (permalink) Old 05-02-2019, 09:18 PM Thread Starter
BH#103's Avatar
Thanks for the input, I know the 17's and newer are slightly different with the install of the aux switch kit. Not much different, but enough to have a different part #. I was asking for the reason of adding fog lights to a bike utilizing the Harley wiring that tees into the front turn signal harness. That is where the wire is that would power up when the left side button on the left switch pack is depressed. I was thinking that because all the other batwing Ultra and Limited models have the switch pack that maybe Harley would throw a bone to the RG Ultra owners and include it. I don't think you need any supporting wiring for the switch pack if you are just utilizing the fog circuit. Back to the drawing board!
"SLIVER"
BH#103 is offline
post #7 of 8 (permalink) Old 05-03-2019, 06:56 AM
The wiring is there to do exactly what you want, you just need to add the switchpack 69200173 and the appropriate switches. The fog lamp switch is part# 71400044. I added these to my 2019 RGU and then used the HD LED Fog Lamp Wiring Harness 69201109 that plugs in at the turn signal connections to hook up fog lights. The bike is basically wired just like the batwing models, as you suspected. The only thing that didn't work was the indicator light on the tach that comes on when you turn on the fog lights. A dealer flash solved that.
BH#103 likes this.
Dagwood08 is offline
post #8 of 8 (permalink) Old 05-03-2019, 08:03 AM Thread Starter
BH#103's Avatar
Awesome! I was thinking the 69200173 was already there, with just dummies in all 3 slots. Good to know, thanks!
"SLIVER"
BH#103 is offline
JSR CUSTOMS BLACK 12" x 1 1/4" APE HANGERS FOR 2017 & NEWER HARLEY ROAD GLIDE LoneCabbage Parts for Sale 11 09-01-2018 10:10 AM
