07 R/G come on instead of turn signal ????? - Road Glide Forums
  • 1 Post By RonC26
post #1 of 4 (permalink) Old 07-08-2019, 01:24 PM Thread Starter
90profx's Avatar
Out of the blue I came out this morning and headed down the street, turned on the turn signal and all 4 start flashing, right or left turn button, doesn't make a difference.........WTH is this all about ??????????
Worked perfect 2 days ago.
90profx is offline
post #2 of 4 (permalink) Old 07-08-2019, 01:42 PM
RonC26's Avatar
Iím sure you tried holding both down for 3 sec or so to see if reset would fix???
smitty901 likes this.
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is offline
post #3 of 4 (permalink) Old 07-08-2019, 02:24 PM Thread Starter
90profx's Avatar
Yep, been there-done that !
90profx is offline
post #4 of 4 (permalink) Old 07-10-2019, 06:31 AM Thread Starter
90profx's Avatar
Ok, pulled the front fairing off and after 3 hrs of pinning out the turn signal wire harness, it came down to a bad ground. I can't figure out how that would cause my problems but it did. I bought the bike used and it was a Florida bike, allot of the connections and fittings have shown some slight corrosion which I've corrected or replaced as found. Cleaned the ground contacts as well as others with a brass wire brush, added Dielectric Grease and reassembled..................Good to go !!!!!!!!!!!!!!!!!!!!!!!!!!!!
I HATE ELECTRICAL PROBLEMS WITH A PASSION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
90profx is offline
