US Fender on Canadian bike - Page 3 - Road Glide Forums
post #21 of 26 (permalink) Old 08-07-2019, 09:52 AM Thread Starter
Ok, so I made a boo boo. I had the TriBar lights connected on the wrong sides. Soooo, with everything directly plugged in, I get all the lights running, and the left turn signal will work. But no brake lights or right signal.
PrimePower is offline
post #22 of 26 (permalink) Old 08-07-2019, 11:28 AM
BH#103's Avatar
You're killin me Smalls! Just kidding. Get out a pen and a notebook and start creating a map of the wiring. Write down what you are doing and what the result is with which wires connected and what that wire is supposed to do.
"SLIVER"
BH#103 is offline
post #23 of 26 (permalink) Old 08-08-2019, 07:30 AM Thread Starter
Haha. Ya, I’ve been trying everything with wire combinations. The only thing I can do is get all the running lights working and left signal. If I touch the Blue/Red to the left side signal, I get brakes just on the left side. No, signal or brakes on right side.
post #24 of 26 (permalink) Old 08-08-2019, 09:23 AM
BH#103's Avatar
I'll consult my manual later, get a look-see again.
"SLIVER"
BH#103 is offline
post #25 of 26 (permalink) Old 08-08-2019, 09:35 AM
BH#103's Avatar
I just looked at the connector pictures I posted again. If a Canadian and US bike are duplicates into the module then make sure your connectors are wired like the US pictures for the module out. Make sure you have the right module too. If that isn't working, then do not connect the lights and just check what signals are coming out of the module. Maybe the module is defective? You do have a US fender and US module right? Make sure the bulbs after good too. Are you checking with DVOM or test light? Make a schematic of what wires are where and take a picture to post it.
"SLIVER"
BH#103 is offline
post #26 of 26 (permalink) Old 08-08-2019, 09:52 AM
Zedbra's Avatar
I have read through this over the days, but not 100% up to speed as to what you are trying to achieve in regards to having the lights running. In Canada, I didn't think we were required to have the signal lights running all the time, just the brake light are wired as such. You would think then that the bulbs would not be dual element and possibly not wired as such. If you want them to run as such, there should be wiring in the tour pack harness that will run the signals as dual, as that is ho the tour pack is wired regardless of country. At least, this is how my 08 is wired tour pack is dual running/turn in red, my lower turn signals are orange and only on when activated by the switch.
2008 FLTRU w/110" SE TC
Zedbra is online now
