US Fender on Canadian bike - Road Glide Forums
post #1 of 26 (permalink) Old 07-15-2019, 12:20 PM Thread Starter
Hey guys, new to the Harley world and to this forum. I just picked up a 2019 RGS. Love the bike, except the taillight. I live in Canada, so we have the big taillight on the rear fender. I managed to pick up a US rear fender to match my billiard blue off eBay. Iíve been searching the forums and cant find anyone that has done this before. I know the wiring harnesses are different, but people also get the CVO fender and make that work, which would be similar to this. Just wondering if anyone has done any wiring related to something like this? Thanks for the help.
PrimePower is offline
post #2 of 26 (permalink) Old 07-15-2019, 01:31 PM
Welcome, sorry I cannot help on your question.
PrimePower likes this.
FLTRXS18 is offline
post #3 of 26 (permalink) Old 07-23-2019, 08:29 AM Thread Starter
So I have my US fender and plugged it in. Everything works except the brakes. Running, TriBar, license plate and signals all work. Anyone on here have any idea what wires should be changed to get the brakes working? Thanks!
post #4 of 26 (permalink) Old 07-23-2019, 09:00 AM Thread Starter
More info. Iíve tried switching plugs around and still nothing. Although now, when I plug it straight into the harness on the bike, I only get the right signal to light up. I plug the factory rear lights in and they all work, with signals and everything. Any help would be great. Thanks
post #5 of 26 (permalink) Old 07-23-2019, 09:01 AM
BH#103's Avatar
You are dealing with the harness that was already on your bike correct? Only the fender with the lights was changed?
"SLIVER"
BH#103 is online now
post #6 of 26 (permalink) Old 07-23-2019, 09:18 AM Thread Starter
Correct. The main harness on the bike is stock. Iím using the rear lighting harness from the US fender. I know the wiring will change slightly, due to the lack of a centre taillight and the TriBar light.
post #7 of 26 (permalink) Old 07-23-2019, 09:27 AM
BH#103's Avatar
Originally Posted by PrimePower View Post
Correct. The main harness on the bike is stock. I’m using the rear lighting harness from the US fender. I know the wiring will change slightly, due to the lack of a centre taillight and the TriBar light.
Just to be clear on this. With the US fender harness plugged into the Canadian bike harness you have everything working except for brake lights. Is that correct?
"SLIVER"
post #8 of 26 (permalink) Old 07-23-2019, 10:27 AM Thread Starter
Well, when I first plugged it in, yes. But now, I have a code, which I cleared. Now the only thing that works is the right signal and i thinks itís actually both filaments on. So brake light on right side and thatís it. I figured the bike probably powered everything up first and then shut it down.
post #9 of 26 (permalink) Old 07-23-2019, 11:13 AM
BH#103's Avatar
Got a manual and a test light? I would figure out what wire is for what on the bike side and make sure it gets to the corresponding wire on the fender harness connector.
"SLIVER"
post #10 of 26 (permalink) Old 07-23-2019, 11:23 AM Thread Starter
I just downloaded a wiring harness diagram. Going to start testing now. I believe the wires swap to different pins at some point. Thanks
