Not to beat a dead horse, but I'm really scratching my head here. I didn't go the CD route. I found some really well made LED 1157 bulb replacements on Amazon... MZS tuning. purchased and installed. They are super bright and work well. The issue i am having is with clearing the codes. I have tried every possible sceniro I could find with making the canbus re-learn the flashers/blinkers without sucess. I don't know what else to try.
Ive tried all the suggestions from CD, which I didn't full expect it to work since it's a different maker.
The hazards/blinkers flash at normal rate, but the dash indicator hyper flashes and it throws all 4 BCM codes for the blinker.
If running the Hazards for about 20 or so flashes doesn't fix the issue I would say that they aren't compatible with the bike. Sometimes buying things at a great price doesn't turn out to be so great. Often you get what you pay for. Sorry
Check with a dealer. I believe there is a setting on the digital technician that will let you change the BCM to recognize the lights as LED instead of incandescent. Might help or might not.
So I tried to remove the main fuse to see if it would reset the module but I didn't work so at this point I am just going to have to deal with it oh well !
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
