Dyno break in - Road Glide Forums
post #1 of 7 (permalink) Old 04-11-2014, 08:10 PM Thread Starter
Olskoo's Avatar
Dyno break in
Is there such a thing as a dyno break in on a complete motor re-build? If so can you ride as normal once it's tuned or treat it as a new bike for 500 miles?
Olskoo is offline
post #2 of 7 (permalink) Old 04-11-2014, 08:59 PM
tsmartt's Avatar
New bike break in to make sure all seals and gaskets are good. At least 500 miles before twisting it hard or down shifting. Then ride it like you stole it. Glide on!
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #3 of 7 (permalink) Old 04-11-2014, 09:41 PM
FrankieB's Avatar
Yes there is such a thing. Take it to someone who knows what they are doing. Once it is broke in on the dyno and tuned properly, ride the hell out of it.
06 RK
11 RGU
FrankieB is offline
post #4 of 7 (permalink) Old 04-11-2014, 10:00 PM Thread Starter
Olskoo's Avatar
Thanks, the shop that built my motor said they're doing a dyno break in and I never heard of that .
Olskoo is offline
post #5 of 7 (permalink) Old 04-11-2014, 10:04 PM
NorCal's Avatar
I had my other bike built and was dyno broke in. I was then told to ride the heel out of it. Also read the attached article talks all about dyno breakin's.
http://mototuneusa.com/break_in_secrets.htm
NorCal is offline
post #6 of 7 (permalink) Old 04-11-2014, 10:36 PM
mocotom's Avatar
A dyno break in is a controlled process of heat cycles and progressive loading of the engine and yes it is very effective. With today"s piston designs, nitride ring packs and a properly honed cylinder there is even less reason to consider doing extreme so called beak in procedures as described in that article.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #7 of 7 (permalink) Old 04-14-2014, 06:23 AM
Right on.
Scott
Hillsidecycle.com is offline
07 and newer motors will break????? gabbyduffy Engine Related 34 02-06-2017 07:12 AM
Build/Break In Done. Dyno on 29 Mar!! adrenilinecrash Road Glide Builds-Document your builds HERE --NEW 1 03-30-2013 11:11 PM
Finished the 500 mile break-in!!!! G *General Road Glide Discussions/Pictures 23 01-22-2011 10:14 AM
Thoughts on break-in HD_Shock *General Road Glide Discussions/Pictures 12 09-28-2010 04:42 PM
Dual front break to single? Not_A_CVO Aftermarket Accessories 1 08-21-2010 10:03 PM
