to cam or not to cam? - Road Glide Forums
post #1 of 8 (permalink) Old 04-22-2014, 01:34 PM Thread Starter
New 1300 miles RGU with fuel moto stage 1 type air cleaner and screaming eagle pipes. Power Vision tuner. Im liking the change with these add ons and the bike pulls well, but I had a 103 with 255 cams on an 09 Road king and Im thinking about adding these to this bike - but is it worth the $.
I want/have to stay with harley cams because I have an extended warranty and will have them do it before 60 days from purchase is up - so they will be covered too.
Looking at the screaming eagle cams Im wondering about the 259 too. It looks like it comes on a little later than the 255 and stays on for higher RPM's
Im a big guy 290 lbs and I liked the torque from the 255's
bikerbehaviorist is offline
post #2 of 8 (permalink) Old 04-22-2014, 02:52 PM
mocotom's Avatar
There are better choices in cams for a 103 IMO, but if you can only use HD cams my suggestion (considering your total vehicle weight) would be the 255's.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 8 (permalink) Old 04-22-2014, 03:34 PM
Redbeard77's Avatar
The 259s need more compression, so would be a bad choice for a cam-only job. You know the 255 from past experience, and the 254s are also a good option and carries the power curve a little further.
Also look into the 204s. They're not as strong as the 255 on the bottom end, but have a broad range and should make more hp overall.
Happiness is a warm motorcycle.
Redbeard77 is offline
post #4 of 8 (permalink) Old 04-22-2014, 03:52 PM
sloride's Avatar
X2
sloride is offline
post #5 of 8 (permalink) Old 04-22-2014, 11:03 PM
If it was me I would stick with the 255's. I was faced with the same decision and I'm loving the torque. I know there's better out there but that's the best HD cam for my needs.
2012 FLTRX
Sideways is offline
post #6 of 8 (permalink) Old 04-23-2014, 02:46 AM
Taccone's Avatar
I have the se254e cams and love them! I have a cousin who has the 255's in his street glide and I always pull away slightly in a race. I'm not the better rider and our bikes are set up the same, the 255's just fall on their face in power early in rpms where the 254e cam's lets you build power too redline. The 254e cam's also don't destroy fuel mileage like the 255 torque monsters do. Riding both bikes they feel similar, the 255 does have a lil more low end grunt but the power quicly fades as the rpm's build, where the 254e cam just feels like a stock motor with just more power everywhere in the rpm band. There are much better choices for a cam for our bikes, but if staying with HD look at the 254e cam.
Taccone is offline
post #7 of 8 (permalink) Old 04-23-2014, 05:56 AM
The 255 school bus/emission cams should not create poor fuel economy.
Perhaps a ride up to Corfu, N.Y., to vist Dan Thayer, Thayers Sales & Service, would/could correct that.
Scott
Hillsidecycle.com is offline
post #8 of 8 (permalink) Old 04-23-2014, 07:59 AM
equandt's Avatar
If I had to choose a SE cam to go with a 103 touring bike, it would be the SE204. I don't think you would be disappointed with a SE204. Pulls like a freight train down low and runs out pretty well to 5500 rpm.
Good luck
2012 FLTRX
2010 FLHTCU
equandt is offline
To cam or not to cam, that is the question.... mastergunnera8 Engine Related 16 02-20-2017 11:10 AM
2012 103: to Cam or not to Cam? 57Glide *General Road Glide Discussions/Pictures 13 02-09-2017 07:09 PM
Cam or not to cam! Tiz the question pipe3214 Engine Related 6 02-13-2015 03:59 PM
To Cam or not to Cam Mdwatson Intake and Exhaust 14 01-14-2015 12:55 PM
To Cam or Not To Cam is the Question? Cmathias Engine Related 29 07-11-2013 01:25 PM
