Solid or Adjustable Pushrods? - Road Glide Forums
post #1 of 16 (permalink) Old 04-23-2014, 03:17 PM Thread Starter
I will have the Screaming Eagle hydrolic cam tensioner plate installed in my 2006 next week. Should I stick with solid pushrods or have adjustable pushrods installed? Does anyone with a pre-2007 FLT have experience with the hydrolic cam tensioner plate and push rod conversion?
grambo is offline
post #2 of 16 (permalink) Old 04-23-2014, 03:23 PM
adjustable pushrods, don't they come with it? You getting the oilpump and all
reds4 is offline
post #3 of 16 (permalink) Old 04-23-2014, 03:51 PM Thread Starter
No. The cam plate does not come with adjustable push rods. It does come with the new oil pump, tensioners, and a chain. I have also purchased the cam kit which includes bearings and gaskets, a shim kit and a drive gear retention kit.
grambo is offline
post #4 of 16 (permalink) Old 04-23-2014, 03:53 PM Thread Starter
I am kind of interested in finding out if the original owner installed adjustable push rods when the 95" big bore kit was installed. Is it easy to move the push rod tubes to check the push rods?
grambo is offline
post #5 of 16 (permalink) Old 04-23-2014, 04:16 PM
Durwood's Avatar
I prefer the stockers, depending on the cams you have.
Don't forget the tune.
Durwood is offline
post #6 of 16 (permalink) Old 04-23-2014, 04:35 PM
Id get adjustable so if you go to swap out cams you don't have to remove the heads. But, if you would rather save the $100 then do the extra labor.
It seems that price wise it would be pretty close to the same either way as it will cost more labor to remove the heads than to cut out stock push rods and put in adjustable. Doing it myself adjustables for sure.
HogPro is offline
post #7 of 16 (permalink) Old 04-23-2014, 04:37 PM
Durwood's Avatar
The heads don't have to come off, remove the tank, upper rocker box and rockers..
Piece of cake..
Durwood is offline
post #8 of 16 (permalink) Old 04-23-2014, 04:58 PM
+HogPro, that's what they make boltcutters for
reds4 is offline
post #9 of 16 (permalink) Old 04-23-2014, 06:28 PM
sj01fltri's Avatar
I did the screaming eagle cam plate with hyd tenisoners,plus upgraded oil pump on my 01 RG,was very straight forward conversion,i would run the adj push rods,if at any time you want to do a cam swap it makes it a little simpler to do.IMO,had better oil pressure at idle while hot after doing the conversion.
sj01fltri is offline
post #10 of 16 (permalink) Old 04-23-2014, 06:45 PM Thread Starter
Great advice. I was reading on one of the other forums that some folks had probs with the adjustables; the lock nuts vibrating loose or even breaking in half. Have you adjustable p.r. been reliable?
grambo is offline
Confused on adjustable pushrods ironmike666 Engine Related 25 04-16-2014 08:21 PM
Quick install adjustable pushrods? Papi63 Engine Related 12 01-22-2014 07:54 PM
3 Hours for Adjustable Pushrods? OldNerdGuy Engine Related 8 06-14-2012 07:01 AM
Adjustable Pushrods 17997-99A PC PaiN Classifieds Archive (3 months old+) 0 05-29-2011 04:45 PM
Dynojet Power Vision - and adjustable pushrods CHAINSAW Fuel Moto 0 03-14-2011 05:19 PM
