Install compression releases with heads on the engine? - Road Glide Forums
post #1 of 13 (permalink) Old 04-29-2014, 09:06 AM Thread Starter
I have been told by two different HD shops that they can install compression releases without removing the heads. Has anyone had releases installed this way? How did they turn out any issues after the install?
Thanks.
Reddobe1 is offline
post #2 of 13 (permalink) Old 04-29-2014, 09:14 AM
OldNerdGuy's Avatar
I guess that depends on whether the heads are pre-fitted for them (do they sell heads pre-drilled?). If they have to do any machining, not a very good idea. I would not like to have my cylinders filled with metal shavings.
OldNerdGuy is offline
post #3 of 13 (permalink) Old 04-29-2014, 09:21 AM
I agree with ONG, unless for some strange reason there's already a hole tapped for the CR's and it's plugged off, no way are you drilling my heads on the bike.
Sent from my SPH-L710
post #4 of 13 (permalink) Old 04-29-2014, 02:14 PM Thread Starter
No the heads are not per machined for releases. They have a fixture that is secured to the top of the head after the rocker boxes have been removed. They do all the machine work except the small hole that goes into the combustion chamber. They then screw a fitting into the spark plug hole and pressurize the cylinder with air. Then drill the small hole into the chamber and any chips blow out. At least that is how the dealers explained it to me.
Reddobe1 is offline
post #5 of 13 (permalink) Old 04-29-2014, 02:38 PM
Hullhorr's Avatar
That sounds like a reasonable approach, but I would still be uneasy doing it that way. The expectation that metal particles would escape thru a small hole make me skeptical.
2009 FLTR MOP
Hullhorr is offline
post #6 of 13 (permalink) Old 04-29-2014, 04:02 PM Thread Starter
That's pretty much how I feel about it. Sounds to good to be true. I was talking to a tool and die maker and he said that he didn't see anything wrong with doing it this way. But I'm a little sceptical. Has any one out there done this with their bike?
Reddobe1 is offline
post #7 of 13 (permalink) Old 04-29-2014, 05:07 PM Thread Starter
OK I sent Jim's performance an email and asked if their compression releases fixture can be used with the heads on the engine. They said do not use fixture with heads on the engine. That solves that.
Reddobe1 is offline
post #8 of 13 (permalink) Old 04-29-2014, 05:46 PM
I 'Always' ask the dealership or anyone doing work to explain, step by step, how any work will be done.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #9 of 13 (permalink) Old 04-29-2014, 05:50 PM
OldNerdGuy's Avatar
For my bike, I would never do it that way. All it takes is one tiny sliver and you can wreak havoc inside an engine. I believe these are Aluminum heads, so the magnet on the drain plug is not gonna catch it.
post #10 of 13 (permalink) Old 04-29-2014, 08:38 PM
sj01fltri's Avatar
I am a toolmaker with 35 years in the trade,if any body says that they can driil the heads and not get aluminum chips down in the clys,i am calling bullshit,it do this every day and it is amazing how many chips and in what places they get.Blowing air into the clys is their approach of making the customer feel good about it,no way would i have this done.as the drill breaks thru the last bit of chips exit are blocked by the dia of the drill,its only exit is along the relief flutes of the drill which are very small.
sj01fltri is offline
Compression releases not closing Reddobe1 Engine Related 9 08-03-2015 06:12 PM
Compression releases sj01fltri Engine Related 7 01-07-2015 07:10 PM
Install compression releases or change the cams? Reddobe1 Engine Related 9 04-20-2014 11:27 PM
Compression Releases Yes or No.... direwolf Engine Related 13 06-06-2013 07:09 AM
95'' heads high compression pistons and cams OuchMMC Dyno Results 18 04-04-2012 12:14 AM
