Andrews 26G's - Road Glide Forums
post #1 of 17 (permalink) Old 04-29-2014, 04:20 PM Thread Starter
veetwin's Avatar
Andrews 26G's
Ok,I did it! Cams,geardrive,oil pump(new Design from Drag-just like the Fueling but it's only 149 bucks),Fueling spring and Thunder Header! Sounds great,I allways loved the Thunder Header! great oil pressure(even hot).
Torque of the cam is a bit lack luster.I expected more I guess.I honestly can't feel any torque or hp increase over my stock valve train,and Kerker 2 into 1 header.
Anyone had similar results from 26G? Did I make a bad choice? My intent was to get rid of the spring tensioners and gain some torque. I seemed to achieve one of those.
veetwin is offline
post #2 of 17 (permalink) Old 04-30-2014, 06:45 AM
88 ci?
Scott
Hillsidecycle.com is offline
post #3 of 17 (permalink) Old 04-30-2014, 09:29 AM Thread Starter
veetwin's Avatar
Originally Posted by Hillsidecycle.com View Post
88 ci?
Scott
Yes,2003 FLTRI stock internals.K&N inside the stock housing,Thunderheader 2 into 1,S&S gear Drive,26G cams,Psycho lifters,Drag oil pump. I could swear it had more torque with the stock cams in it
veetwin is offline
post #4 of 17 (permalink) Old 04-30-2014, 10:17 AM
Therocks01's Avatar
I just put 21s in my '01 and all I can say is WOW! There is not much difference from 21s to 26s. The 26 just comes on a little later. Was your bike tuned to get every drop out of the new AFR? You don't mention a Power Commander or other tuning device. If you had a shop do the work, did they remap the ECM?
Therocks01 is offline
post #5 of 17 (permalink) Old 04-30-2014, 10:27 AM Thread Starter
veetwin's Avatar
I have not done anything electronic.I that the issue? As mild as these cams are ,I thought I might feel something without any programming. I had pipes and air filter before the cam swap,only thing different is cams and gear drive.
I can see a program to enhance my engine output,but I really did no think this mild of a upgrade was DEPENDANT on pramming
veetwin is offline
post #6 of 17 (permalink) Old 04-30-2014, 01:29 PM
mocotom's Avatar
The ECM has no way of knowing that there is a greater amount of air entering the cylinder due to a cam change so it continues to inject the same amount of fuel as with stock cam. Your 2003 Delphi injection has no oxygen sensor feed back for the ECM to even make an attempt to correct. You are undoubtedly running in a lean a/f mixture condition and needs to be addressed very soon before possible piston damage.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #7 of 17 (permalink) Old 04-30-2014, 02:51 PM
Banned
get a tune
hotrod is offline
post #8 of 17 (permalink) Old 04-30-2014, 03:26 PM Thread Starter
veetwin's Avatar
Ok,I will go that route. ordering a Power Comander.
veetwin is offline
post #9 of 17 (permalink) Old 04-30-2014, 05:36 PM
RoadGlideGary's Avatar
You might want to check with Jamie (FuelMoto) a sponsor here and see what they recommend. They support what they sell with tunes for your current and future mods. You may find a better price but you won't find better support.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #10 of 17 (permalink) Old 05-01-2014, 06:49 AM
9.6 cr is the optimized ratio for the use of an Andrews 26.
That is what we set the 98"ers at when doing that job here.
Most times 110 ft/lbs is where those land.
Check out www.motomummy.com for powercommander pricing.
Scott
Andrews 26 to Andrews 57 Bill-99RG Engine Related 2 02-29-2016 06:28 AM
For sale: Andrews TW26G cam set BigDaveOnBass Classifieds Archive (3 months old+) 5 03-23-2012 11:42 AM
Best price for andrews cams? housei *General Road Glide Discussions/Pictures 4 12-13-2010 11:17 AM
Andrews 48H cams sportyguy69 Engine Related 1 11-25-2010 06:57 PM
Andrews 48H Cams are in... FLTRI *General Road Glide Discussions/Pictures 27 11-01-2010 11:07 PM
