Starter drag - Road Glide Forums
post #1 of 5 (permalink) Old 04-29-2014, 09:43 PM Thread Starter
Olskoo's Avatar
Starter drag
Just had my motor built, 107 with 10.25/1 compression and compression releases installed, I've been noticing when the bike gets hot it almost doesn't want to turn over . Is this common ? If so what's a good high torque starter ??
Olskoo is offline
post #2 of 5 (permalink) Old 04-29-2014, 09:50 PM
sj01fltri's Avatar
What cams are you running.
sj01fltri is offline
post #3 of 5 (permalink) Old 04-29-2014, 10:50 PM Thread Starter
Olskoo's Avatar
S&S 570
Olskoo is offline
post #4 of 5 (permalink) Old 04-29-2014, 11:21 PM
rageglide's Avatar
With compression releases you shouldn't feel the starter struggle. Sounds like weak battery or loose cables. I doubt an aftermarket starter would make a diff. Compression releases blow off more than enough compression to make the engine easy to spin.
That said. You said S&S 570s did you also do get easy start cams? If so it would make the engine harder to start having both EZ starts and ACRs. Wouldn't cause a slow turn over, but rather insufficient compression to light the fire.
2012 fltrx
rageglide is offline
post #5 of 5 (permalink) Old 04-29-2014, 11:23 PM Thread Starter
Olskoo's Avatar
No there not the EZ start cams, I'm gonna check the battery!! Thanks..
Olskoo is offline
Drag Specialties (All Balls) Starter Clutch 2110-0319 Nozzleman 216 Classifieds Archive (3 months old+) 3 01-16-2013 01:08 PM
Starter Hesitation & Fuel Range reading Cotton Hill Troubleshooting for Road Glides 4 05-27-2011 09:37 AM
Rebuild silenoid or replace starter? krgs2k Troubleshooting for Road Glides 6 04-20-2011 05:01 AM
Spyke starter issues Hotroadking Troubleshooting for Road Glides 2 02-15-2011 01:05 PM
Starter Marks07RG Equipment-RG 1 09-21-2010 06:42 PM
