Compensation Sprocket - Road Glide Forums
post #1 of 21 (permalink) Old 04-30-2014, 08:51 PM Thread Starter
I have a 2009 and when I hit the start switch at times I have this ungodly noise. I was at an old country cycle shop and he told me on another customer he replaced 3 starters before he focused in on the compensation sprocket. Lf anyone has any feedback please let me know. I'm heading to the Harley dealer Sunday to try to get this replaced under my extended warranty.
RGCharlie is offline
post #2 of 21 (permalink) Old 04-30-2014, 09:10 PM
Bikes with the 96" motors which I believe 07 to 11ish bikes have had known compensator problems. And yes bad comp will take out the starter too. These bikes mentioned had basically carry over compansator parts from the earlier 88" which are too weak to hold up to the added power the 96"ers made. They upgraded them with the Screaming Eagle versions which come stock on the 103" amd 110" bikes. Some folks had the dealer replace them with the SE comp under warranty
post #3 of 21 (permalink) Old 04-30-2014, 09:16 PM
Your warranty should cover it no problem. Like rlaf75 said, I'd pay the extra to up grade to the SE version .
post #4 of 21 (permalink) Old 05-01-2014, 12:23 AM
rageglide's Avatar
Costs a TON less to put in compression releases auto or manual than even one Starter. There's a reason why the 103's come from the factory with compression releases. They need it with this '06 and up POS compensator.
2012 fltrx
rageglide is offline
post #5 of 21 (permalink) Old 05-01-2014, 01:20 AM
Transplant's Avatar
My compensator shit the bed the end of the season last year. Going to get it replaced on Friday . Freeking Harley junk.
Just my 2 cents.
Transplant is offline
post #6 of 21 (permalink) Old 05-01-2014, 07:00 AM
I'm on my second compensator, the one I have now is the SE, it's starting to make that terrible noise sometimes on start up, when I change again I'm going to something other than HD. I may go to the solid one from Vulcanworks, I looked at the Compensavor but don't know if I want to go that route.
Sent from my SPH-L710
post #7 of 21 (permalink) Old 05-01-2014, 10:21 PM
Hullhorr's Avatar
+1. I'm in the same boat. Seriously considering the Vulcanworks, but still holding out to see if Hoban Bros. come out with theirs.
2009 FLTR MOP
Hullhorr is offline
post #8 of 21 (permalink) Old 05-01-2014, 11:25 PM
mitchdm's Avatar
I went with and have friends that have gone with Vulcanworks Solid Sprocket.
I am a fan and so are those that I know that have converted.
mitchdm is offline
post #9 of 21 (permalink) Old 05-02-2014, 02:01 PM
I went with a solid sprocket from Evolution Industries. Went with their Diamond Terminator clutch (awesome!) and a SE manual adjuster. No issues here whatsoever.
107 w/ T-Man cylinders and pistons, Zipper's stage 3 heads, Feuling 594 reaper cams, HPI 58mm elliptical TB, S&S roller rockers+forged shafts+premium lifters, TMax, D&D, S&S cam plate+pump, Evolution clutch+no comp sprocket, Baker chain tensioner, bottom end by Revolution w/H beams+Timken, Jagg w/fan, Baker DD7 & +1.5 pan, 14" Vindikta bars, Legend Axeo cartridge forks+Revo-A, HD Blade 18+18, Daymakers, Russell Day-Long.
G Ogre is offline
post #10 of 21 (permalink) Old 07-03-2014, 06:04 PM
waynemags's Avatar
34T Motor Sprocket Conversion, 06+ Dynas, 07+ Softails, Dressers- #4513 can someone thats has done the conversion tell me if this is the one from Vulcanworks that will work on a 12 roadglide?
12 FLTRX, Bassani Road rage, Roland sand AC, Thundermax, 16" Apes, custom wheels, SE 255 cams,Barnett Scorpion clutch, progressive 944 rear, Progressive mono lower 1inch front, and soon to come Baker 7 speed, and 11" Madstad, HD Daymakers
waynemags is offline
rear sprocket & saddlebag guard bags tj316 Classifieds Archive (3 months old+) 0 02-27-2011 06:14 PM
2010 Chrome Sprocket Cover cleanrider Aftermarket Accessories 4 01-25-2011 07:30 PM
Compensator sprocket tourglide Troubleshooting for Road Glides 13 01-18-2011 02:47 PM
