98 help - Road Glide Forums
post #1 of 12 (permalink) Old 05-01-2014, 11:44 AM Thread Starter
98 help
Hi guys. I'm really new to this so please be patient with me. I want to put an ev27 can in my 98 roadglide FLTRI. It would be great if I could get some direction on what I need and the pluses and minuses of running that Cam on a fuel injected bike. Please help!!
bigrednick is offline
post #2 of 12 (permalink) Old 05-01-2014, 05:13 PM
sj01fltri's Avatar
You will need some type of tuner on it,i put SE 211's and head work with a 95 inch kit in my 01,that is when the tuners were fairly new to the market,used a power comander never did get it tuned right,so i converted to a carb,was the best thing i ever did.
sj01fltri is offline
post #3 of 12 (permalink) Old 05-01-2014, 06:36 PM
We've used a metric ton of those 27's, and Wood 6 cams in those 80"s with large results.
The 27 likes 9.8 cr and a Wood 6 can go to 10.2, BUT, if looking for big grunt with a good hp charge as well, Crane hit a home run with the 300.
Big torque right up off the bottom, where a heavy touring machine can really use it.
9.4 cr is where we set that, and actually have 2 jobs in here now using that cam.
Scott
Hillsidecycle.com is offline
post #4 of 12 (permalink) Old 05-01-2014, 07:34 PM
mocotom's Avatar
Couldn't agree more with Scott's choice, the 300 is a great cam for the Evo.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 12 (permalink) Old 05-02-2014, 09:49 AM Thread Starter
Thanks guys for the information. I'll definitely look in to the Crane. I don't have the budget to mill the heads yet but I would like to. I've heard of guys converting to carb burn§ also heard that is have to augment my wiring harness? The motor was replaced by Harley when the last owner did the exchange program. I was surprised when he told me they replaced the entire motor and was a bit suspicious until he showed me the paperwork. So the motor now currently only has 11,000 miles on it. Should I replace the lifters when I do the cam? And does anybody know a good place to get a breather gear for a decent price? Sorry for l the question. First big v-twin I've owned, if it was a chevy 350 I'd be all over it
Ps disreguard the spelling mistakes I'm posting from my phone and it likes to AutoCorrect the crap out of me
post #6 of 12 (permalink) Old 05-02-2014, 06:37 PM
sj01fltri's Avatar
Every thing to convert to carb is plug and play using HD parts,sub wiring harness ect,took me about 4 hrs to complete it.
post #7 of 12 (permalink) Old 05-02-2014, 11:04 PM Thread Starter
Really.....hmmm because the MM EFI sputters and stumbles at first. Almost like the timing is off. Would you happen to know where I can find some info on what I'd need? I can get my hands on a CV carbs/intake for really cheap. I'd probably need to remove the fule pump and swap out the ignition?
post #8 of 12 (permalink) Old 05-03-2014, 05:18 AM
Not only can we suggest the proper components/work, but can sell the parts to you as well.
Scott
post #9 of 12 (permalink) Old 05-03-2014, 03:21 PM Thread Starter
I'm sure you Guys would Scott! Lol
post #10 of 12 (permalink) Old 05-06-2014, 06:37 AM
You just need to find a tuner that knows how to tune the MM system.
They are out there.
Scott
Tags
1998 , ev27
CB Installation on '98 Road Glide - HELP! tvwwingman Audio 2 01-20-2015 07:47 PM
difference 98-03 vs 04-10 windshield? larsfum Windshields 6 01-09-2013 09:12 AM
98 Roadking to 2003 Roadglide allmost57 New Members Welcome Area 13 11-14-2011 08:30 PM
J&m fairing acoustic pad harley davidson fltr 98-10 NakedSnowman Audio 0 06-07-2011 11:02 PM
Harley Davidson Helmet Headset 77147-98 NO RESERVE Timinfla2 Classifieds Archive (3 months old+) 0 04-29-2011 05:10 AM
