ticking noise - Road Glide Forums
post #1 of 3 (permalink) Old 05-02-2014, 09:45 AM Thread Starter
JJSW1283's Avatar
ticking noise
So on the way back from memphis last week, got caught in a traffic jam on the interstate. Bike overheated, and as soon as we got through it the bike pinged like hell until we got back up to speed and cool off some. Well maybe 15 miles later on I40 where TN crosses into NC I was in 6th gear kind of going up a incline when the bike stuttered 3 quick times together. Dropped to 5th a rode aways, then back to 6th. I tried my best to get it to happen again with no luck. Got home, parked it. Pulled out of garage to wash it last night. While backing back into garage I had the bike off and in neutral and it was making some kind of clicking noise with I was rolling. Kind of sounded like a baseball card between bicycle spokes. Any ideas?
JJSW1283 is offline
post #2 of 3 (permalink) Old 05-02-2014, 03:17 PM
FrankieB's Avatar
Sounds like the belt was just realining (sp?) itself on the pully. I would also check the belt guard and see if it is rubbing. The belt will shift from side to side when you roll the wheel in different directions.
06 RK
11 RGU
FrankieB is offline
post #3 of 3 (permalink) Old 06-07-2014, 05:31 PM Thread Starter
JJSW1283's Avatar
It ended up being the hard plastic hose that comes down from the gas tank. It must have been that way for a while because it was wore down from rubbing the belt.
JJSW1283 is offline
Ticking noise after A/C install blj9511 Intake and Exhaust 6 07-13-2015 08:32 AM
SE120R with ticking noise uaeproz Troubleshooting for Road Glides 2 04-23-2012 03:43 PM
Ticking at 2m RPM zincit Road Glide Specific Discussions 13 07-26-2011 12:21 PM
Ticking at 2m rpm zincit Troubleshooting for Road Glides 0 07-22-2011 12:01 PM
ticking sound newtome Troubleshooting for Road Glides 18 03-22-2011 08:54 PM
