resonable cam lift - Road Glide Forums
post #1 of 13 (permalink) Old 05-04-2014, 09:04 PM Thread Starter
Darreldanger's Avatar
resonable cam lift
Hey guys, I am in the market for a cam for my 2012 RG w/ a 103, how much is too much cam lift. I don't want to go too big and have to replace lifters every winter, but I do want to get as much as I can get by with. I see HD uses a 550 lift on the popular 255 cam I would assume this is safe to keep the bike in warranty... I know they will take more than that but at what cost?
Darreldanger is offline
post #2 of 13 (permalink) Old 05-04-2014, 09:10 PM
I suggest you do the search for cams on this site. You'll get all kinds of info. Educated your self & do a web search for cams & see what kind of changes your looking for. Good luck.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 13 (permalink) Old 05-04-2014, 10:14 PM
faststan's Avatar
Call Frank Drago's to get the actual scoop. Start your research there.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #4 of 13 (permalink) Old 05-05-2014, 02:14 AM
Taccone's Avatar
Like the other 2 stated, do a search. There are more factors to look at than just "lift" on a cam. Learning to read a cam's specs will tell you how the cam will perform, what power range it will work in and such. Call Frank at Drago bike Works to get started.
Taccone is offline
post #5 of 13 (permalink) Old 05-05-2014, 07:02 AM
The lift is only one part of the equation in order to select a cam.
Intake closing numbers that do not match your compression ratio can actually have your bike with less power than it currently does now.
After doing this for 3 decades, drag racing AHDRA and ECRA for almost a 10 year period, and working on motorcycles since 1978, we have the answers to your questions.
Feel free to call us.
Scott
Hillsidecycle.com is offline
post #6 of 13 (permalink) Old 05-05-2014, 08:11 AM
Banned
like hillside said,lift is probably the LEAST important part of choosing cams.timing & duration is much more important to get the power in the RPM range you want it in
hotrod is offline
post #7 of 13 (permalink) Old 05-05-2014, 03:08 PM
The stock heads with stock valve springs are good to .600 lift max.
I wouldn't go much more than .555 with stock valve springs just because I wouldn't want my valve springs at max.
IMO .555 lift is plenty on these engines unless you are doing a monster build.
post #8 of 13 (permalink) Old 05-05-2014, 03:40 PM
Bigfoots03hd's Avatar
I have the same bike and my Harley guy recommended the Harley SE-254E cam. I already have stage 1 and doing header when I do cams. Like everybody else said do your research and talk to people that know our motors and what they can handle without going crazy.
Bigfoots03hd is offline
post #9 of 13 (permalink) Old 05-05-2014, 08:03 PM
Banned
ide bump the compression to 10.0-1 and go with the S&S .570 over the SE 254E.the .570 wont hit quite as low as the 254E,but will carry higher and give VERY good power in your useable RPM range (def. stay away from the 255)
hotrod is offline
post #10 of 13 (permalink) Old 05-06-2014, 04:19 AM
Taccone's Avatar
I have the 254E cam in my bike, was installed free under a warr. issue I had when the bike had 1K miles on it. I'm completely happy with it given to me free of charge, but if I paid for it myself I would've chosen a slightly more aggressive cam myself, but again I'm happy and will not spend the money swapping it out. Sounds good, performs much better over stock too.
Taccone is offline
Should I get a jack lift or a table type lift MarkL *General Road Glide Discussions/Pictures 32 04-01-2017 10:08 PM
To Lift Or Not to Lift Texas Rapier *General Road Glide Discussions/Pictures 6 05-30-2016 09:03 PM
HF 1000lb lift table lift Blackbag1 Do-IT-Yourself 44 06-11-2015 06:49 PM
Looking for high lift torque cam adrenilinecrash Engine Related 46 10-19-2013 01:39 PM
Cam overlap s&s 570 lift SMOKENJOE Tech Area 10 04-23-2013 12:42 AM
