Oil pressure up and down - Road Glide Forums
post #1 of 6 (permalink) Old 05-05-2014, 10:59 AM Thread Starter
I'm experiencing a huge variance in oil pressure.
When the bike is cold it is around 32 steady. Then once I've been out cruising for a while, the oil pressure drops with rpm at an idle.
Once I take off from the light or whatever, pressure comes back up?
What could be causing the variance? I'd hate to hurt her....
LuckyOnes is offline
post #2 of 6 (permalink) Old 05-05-2014, 11:02 AM
PGR
PGR's Avatar
At idle, oil pressure will drop to a very low level, like 5 to 8...... Don't worry.... it's normal. Running down the road your pressure should be around 32 or so. It varies from bike to bike. The gauge is not a precision instrument.
Ron..........................
PGR is offline
post #3 of 6 (permalink) Old 05-05-2014, 07:35 PM
sj01fltri's Avatar
What PGR is telling you is exactly right these engines are roller bearing rods,they dont need high oil pressure at an idle.
sj01fltri is offline
post #4 of 6 (permalink) Old 05-05-2014, 08:58 PM
The previous posts pretty much hit the nail on the head. The important thing is that it's full and it does come up off of idle
post #5 of 6 (permalink) Old 05-06-2014, 06:33 AM
To answer the question, as to what is causing the pressure to drop once it comes to full operating temp, is that the oil viscosity thins up under heat.
If it is moving around after fully warmed, then the oil pressure relief plunger is sticking in it's bore, and can be polished to stop it from occuring.
Scott
Hillsidecycle.com is offline
post #6 of 6 (permalink) Old 05-08-2014, 04:04 PM Thread Starter
Thanks guys.
Oil Pressure And Loud Tranny chkywuky Troubleshooting for Road Glides 5 09-18-2013 03:46 PM
Low Oil Pressure And Noisy Tranny chkywuky Troubleshooting for Road Glides 4 09-18-2013 12:29 AM
Oil Pressure Pegged At Start Up Badnooze Troubleshooting for Road Glides 1 07-11-2013 10:10 AM
Loss of oil pressure and noise mrmoto95 Engine Related 13 05-17-2013 08:47 PM
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
