Stuck on cams - Road Glide Forums
post #1 of 15 (permalink) Old 05-06-2014, 06:19 PM Thread Starter
Stuck on cams
Yea, more cam questions. Cant make up my mind between woods 222 or woods 777 cams. I have 2012 fltrx, lsr 2 into 1 exhaust, v&h intake,screamin eagle race tuner. I ride mostly 1 up and all kinds of riding. Need some opinions.
Thanks in advance
jj8823 is offline
post #2 of 15 (permalink) Old 05-06-2014, 06:45 PM
HellInABucket's Avatar
I would call Fuel Moto, who knows the cams you are considering. From what I know, if you're just going to bolt in a cam, the 222 is a great cam. The 777 needs more compression and ported heads. But I'm just an idiot, call Fuel Moto.
HellInABucket is online now
post #3 of 15 (permalink) Old 05-06-2014, 07:25 PM Thread Starter
You are probably right. Thx for replying HIB
jj8823 is offline
post #4 of 15 (permalink) Old 05-06-2014, 09:27 PM
pat123's Avatar
pat123 is offline
post #5 of 15 (permalink) Old 05-07-2014, 06:42 AM
mocotom's Avatar
Thanks in advance
The two cams your asking about are completely opposite of each other. The 222 is a great bolt in cam for a 103" and has strong low and mid-range power. Like HIB said, the 777's want more comp. and will be a disappointment in a stock motor at anything less than 3000 rpm.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 15 (permalink) Old 05-07-2014, 08:01 AM
Banned
if doing cams only,you want to look at the Andrews 48 too
hotrod is offline
post #7 of 15 (permalink) Old 05-07-2014, 09:29 AM
StGhost's Avatar
I run the 777 now. When I change cams it will be to A Tman sm600. You may want to look at his cams.
StGhost is offline
post #8 of 15 (permalink) Old 05-07-2014, 02:56 PM
Wildmank99's Avatar
I would call Frank at Dragos bike works. I just ordered his 580 cam.
Wildmank99 is offline
post #9 of 15 (permalink) Old 05-07-2014, 04:18 PM Thread Starter
Thanks fellas for the replies,back to my homework i guess. So now its between dragos 580 and woods 222.
jj8823 is offline
post #10 of 15 (permalink) Old 05-07-2014, 04:28 PM Thread Starter
Anyone have any numbers on the dragos 580 cam?
jj8823 is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
Ignition switch Stuck & i mean stuck.... maddmoe Troubleshooting for Road Glides 11 07-08-2016 06:22 AM
Stuck between the V&H PRO PIPE or ThunderHeader? gabbyduffy Intake and Exhaust 32 10-30-2015 03:18 PM
Ok.. Now I am stuck (Handle Bar internal wiring) habu_sake Controls & Handlebars 16 01-11-2011 09:36 AM
Help! I need to remove stuck cd from stereo GLIDEMAN68 Troubleshooting for Road Glides 1 09-30-2010 10:25 PM
