Cams vs. Stage 4 - Road Glide Forums
post #1 of 14 (permalink) Old 05-12-2014, 08:54 PM Thread Starter
Brianu1's Avatar
Cams vs. Stage 4
By the looks of most dyno results the stage 4 kit only gets on average about another 5-10hp and Tq (if the intake and exhaust has been done). So my question is why spend all that extra money for a stage 4 when it looks like cams are very close to the same performance, or am I missing something. I know all dyno's are different so that is probably part of it, but is was thinking stage 4 and now I am rethinking it. Any input is welcome. Txs
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 14 (permalink) Old 05-12-2014, 09:50 PM
Your right stage IV builds don't give you that much more bang for the buck. A good cam, exhaust and intake upgrade with a good EFI tuner and a dyno will give you all you really need for a good rideable touring bike.
post #3 of 14 (permalink) Old 05-12-2014, 11:04 PM
Hullhorr's Avatar
If that's all a stage 4 will net you then yes, add cams, intake, exhaust, tuner, and maybe some headwork, and you can gain a lot more than that.
2009 FLTR MOP
Hullhorr is offline
post #4 of 14 (permalink) Old 05-12-2014, 11:10 PM
Craigmier's Avatar
Fuel Moto's 107 kit appears to give numbers close to 120R motors with cams intake and exhaust. Check out their stuff yet? I would really be considering that if I was in that market. I may go that route after I ride the piss out of my Stage 2 with SE255 cams. Bike runs hard and fantastic with the SE tuner and a dyno tune so will run this for a few more years.
I havent heard or seen many intriguing stage 4 kits done on this forum or in person, atleast not the harley one.
'13 FLTRX - Big Blue Pearl - 16" Carlini Gangster Apes - V&H Power Dual Headers - CFR's - SE255 cams - SE Billet Cam Plate w/High Flow Oil Pump - SE Billet A/C - SERT - Dyno Tune - Daymakers - LRB Carbon Black Rotors - Progressive Suspension - H-D Vented Lowers - Bitchin Stitchin Custom Seat - Rockford Amp - Infinity 6.5's - GADS
Craigmier is offline
post #5 of 14 (permalink) Old 05-13-2014, 06:37 AM
Very straightforward to establish north of 120/120 with a 107".
We were doing that on S&S 107" engines loooooooong before these messages boards were invented.
Scott
Hillsidecycle.com is offline
post #6 of 14 (permalink) Old 05-13-2014, 06:57 AM
strokerjlk's Avatar
Stage 4
Used tman 590 cams instead of SE cams .
Although the SE 259 does pretty well also .
If your stage 2 ( just cams ) does 93 /110 that's 20 hp less and 10 tq less .
Big difference
strokerjlk is offline
post #7 of 14 (permalink) Old 05-13-2014, 09:12 AM
sloride's Avatar
Exhaust, Intake,Tuner, Cams and tune will really give you a good bang for the Buck and you can do it in phases to help on cashflow
If you have the funds, I would go the 107 route before going the HD stage 4
IMO The 107 build seems to offer a better bang for the buck than the Stage 4
BTW...my opinion and $5 will get you coffee at Starbucks
sloride is offline
post #8 of 14 (permalink) Old 05-13-2014, 09:20 AM
neverdone's Avatar
After stage1 77 hp 88tq. SERT V/H high output 2 into 1 pipe and new air intake. Stage4 121 hp 118tq. Same tuner, same pipe. I did change the air intake. For me it was worth it. I wanted a bike that I could pass with and get back to cruising (with the wife).
neverdone is offline
post #9 of 14 (permalink) Old 05-13-2014, 09:24 AM
Deadstroke's Avatar
Harley Stage 4 kit is the most unreliable kit for numbers have I have seen.. I have seen 106 to 120 on dyno sheets for those kits.. I can get over 100 with cams, pipes, air, tuner and a .030 head gasket. If you are going to do anything go with a 107 from:
Fuelmoto, Frank or Hillside
These guys all know their business and offer the best kits with the most consistant dynos out there.
Deadstroke is offline
post #10 of 14 (permalink) Old 05-13-2014, 09:38 AM
tdkkart's Avatar
I'd have a really hard time cracking open a good solid 103" motor just to add 4 cubic inches. Heads, and the right cams with the correct compression will gain you much more than the 4 cubic inches.
The Harley "stage" builds are all pretty conservative and generic.
I keep waiting for something to die in the bottom end of my motor so I have an excuse to build a big inch touring motor.
tdkkart is offline
Stock vs Arnott vs Legends vs HD Premium SEUGOT1 Suspensions 15 04-25-2017 11:10 AM
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
Arlen Ness Stage 1 vs Stage 2 911Shark *General Road Glide Discussions/Pictures 2 01-14-2015 01:39 PM
110ci stage 1 vs 103 stage 4 kits Symp1969 *General Road Glide Discussions/Pictures 19 03-04-2014 11:23 AM
Stage 1 Flash vs. efi tuner vs. PV???? Halstem1 Fuel Moto 5 05-14-2013 10:32 PM
