New build, oil out through exhaust?? - Road Glide Forums
post #1 of 31 (permalink) Old 05-14-2014, 12:37 AM Thread Starter
DONVITO's Avatar
Can anyone help shed some light on this issue I have with a new build?
Its a 07 96 punched out to a 103 with Screaming Eagle MVA heads, 10.5:1 SE pistons with their SST rings, standard bore. During the initial start up everything was fine through several heat cycles then proceeded on a low speed road test for a total of 32 miles, upon return smelled oil and the pistons had oil on them and the valve ports in the heads were saturated with oil.
Took it down, disassembled the heads and the machinist said everything was ok, sometimes those rings would skate on top of the oil on the walls and push it out the exhaust.
Reassembly #2 ball honed the walls and installed a new set of rings into a dry cylinder. After another few heat cycles there was oil again on the pistons and going into the heads.
Right now the cylinders, pistons and heads are back at the machine shop. So far the update to me is the rings and cylinders are set up correctly, and they are going to reinspect the heads and look into to see if theres another set of rings that may be better.
Any of you engine guys heard of this issue and moreso would you have a suggestion on what to do next?
Sure appreciate any help.
DV
2012 CVO Roadglide Custom in Candy Cobalt/Twilight Blue, and it is almost completely stock. :0)))))
Mods are: Fullsac 1-3/4" baffles, Ohlins 6's (HD357), color matched chopped tour pack. Bluetooth stereo with Arc Audio amp and Focal speakers. On the bucket list; Ohlins drop in fork cartridges and the install of Fuel Moto catless 212 SS headpipe
DONVITO is offline
post #2 of 31 (permalink) Old 05-14-2014, 01:10 AM
tdkkart's Avatar
Did you find any oil in the throttle body, intake manifold and intake ports??
Sent from Motorcycle.com App
tdkkart is offline
post #3 of 31 (permalink) Old 05-14-2014, 01:18 AM Thread Starter
DONVITO's Avatar
Throttle body and intake were dry, I think it was just coming out the exhaust, but there may have also been some in the intake port that I suspect was from valve overlap maybe?
DONVITO is offline
post #4 of 31 (permalink) Old 05-14-2014, 01:20 AM Thread Starter
DONVITO's Avatar
The TB and intake were dry, the oil was in the exhaust port and going out the pipe.
DONVITO is offline
post #5 of 31 (permalink) Old 05-14-2014, 02:07 AM
tdkkart's Avatar
They've been known to leak oil down past the valve guides if the guides are fit too loose in the heads.
tdkkart is offline
post #6 of 31 (permalink) Old 05-14-2014, 06:27 AM
Prior to a complete teardown, a leakdown test will in fact pin-point the area that needs attention.
If it is getting past the rings, those bores need to be inspected with a .0001" dial bore guage, for starters.
Scott
Hillsidecycle.com is offline
post #7 of 31 (permalink) Old 05-14-2014, 07:20 AM
mocotom's Avatar
Either the machinist completely botched his part or whom ever assembled the motor installed the top two rings upside down.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #8 of 31 (permalink) Old 05-14-2014, 09:47 AM Thread Starter
DONVITO's Avatar
The rings were correctly installed fwiw. Im not sure if the wrench did a leakdown i didnt ask. But at this point its all apart at the machinists. My guess is that perhaps the bore is too large for the piston/ring fit. These heads were new with 8k miles on them, the were disassembled, inspected and cleaned up and reassembled with new upgraded valve seals. I didnt have this problem before the motor teardown initially but they had the wrong pistons and rings installed in the first place. Long story short the indy that rebuilt my motor the first time really overstated his ability. Thanks for the replys
DONVITO is offline
post #9 of 31 (permalink) Old 05-14-2014, 10:33 AM
If everything was assembled correctly then I would suspect that the jugs were punched out to big so have the jugs checked.
If the jugs were punched to the point that you can't use .010 over pistons and rings you may want to go with new jugs.
I got brand new HD 95/103 jugs from PC Pain for around $250 a pair which is cheaper than buying new .010 over pistons and rings.
The only other problem would be that the rings were not clocked correctly and oil was passing the rings.
post #10 of 31 (permalink) Old 05-14-2014, 11:06 AM
Banned
was there oil on the piston?,if it was fairly dry,its most likely a ex guide
hotrod is offline
Backfires through the exhaust Wood Engine Related 16 12-23-2015 08:00 PM
Blacked Out Shark build LuckySOT Road Glide Builds-Document your builds HERE --NEW 47 07-03-2012 12:25 PM
2012 rgc build blk out crossbones1989 Road Glide Builds-Document your builds HERE --NEW 10 06-06-2012 10:47 PM
Oil burn on a new build??? RoadGlide0611 Engine Related 4 05-12-2012 08:06 AM
New Year, New Bike, New Build! J.I.M.S. Road Glide Specific Discussions 8 01-02-2012 10:20 PM
