Compensator or valve train noise???? - Road Glide Forums
post #1 of 20 (permalink) Old 05-14-2014, 03:15 PM Thread Starter
StGhost's Avatar
need opinions... I have a noise on the left side of engine that I can here going down the road and it sounds like valve tap. It is the louds around 2900rpm and at cruise. If you accel, decel or go up/down a incline the nosie goes away. I have adjust the valves, changing perload, changed the oil to differrent weights and nosie doesn't change and has gotten worst over the last 7 months. Any help please.
StGhost is offline
post #2 of 20 (permalink) Old 05-14-2014, 03:42 PM
Hullhorr's Avatar
Sounds like it could be the compensator, but noises are hard to diagnose.
2009 FLTR MOP
Hullhorr is offline
post #3 of 20 (permalink) Old 05-14-2014, 03:55 PM
PGR
PGR's Avatar
Does it sound more like an almost light wooden ticking sound? Injectors can make a noise like that. One of my tech friends called it injector bounce. Mine sometimes does it when I'm on cruise control and flat L O N G roads and at about 2700 rpm.
Ron..........................
PGR is offline
post #4 of 20 (permalink) Old 05-14-2014, 04:12 PM
Ditto what Ron said!
ksarauer is offline
post #5 of 20 (permalink) Old 05-14-2014, 04:45 PM
tdkkart's Avatar
The compensator is going bad in my '11 RGU, it rattles when I shut the engine off, and it knocks if I don't use enough throttle pulling away from a stop, but it never makes any noise at steady throttle on the highway.
Yes, injectors can be quite noisy sometimes, as can the valvetrain at certain rpms.
Personally, I think the "bad" compensators are getting blamed for a lot of stuff they shouldn't be.
I'm hoping Dark Horse Crankworks releases their new compensator this summer, 'course i hoped that all last summer too........
tdkkart is offline
post #6 of 20 (permalink) Old 05-14-2014, 05:09 PM
FDR's RGC's Avatar
Got the same noise . Changed compensator to Vulcan Engineering sprocket. Still have the noise. Getting ready to pull the outer primary and fire it up and listen. Bike runs great except for the noise.
FDR's RGC is offline
post #7 of 20 (permalink) Old 05-14-2014, 05:12 PM
Sounds almost exactly to noise I had in my bike. Was bad lifters along with other issues. Tear down revealed problems, including bad compensator. Total rebuild required to replace all damaged parts. Hope that not your situation, but afraid it could be. Good Luck!!
1 HD ULTRA is offline
post #8 of 20 (permalink) Old 05-14-2014, 05:42 PM
FDR's RGC's Avatar
Like what other problems? What parts were damaged? What year is bike? How many miles?
post #9 of 20 (permalink) Old 05-14-2014, 05:47 PM
I had a bad comp & it made some noise while riding, but when I shut off the bike it would make a loud clunk. Replaced under warranty. If you find the issue, let us know the problem. Good luck.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #10 of 20 (permalink) Old 05-14-2014, 06:21 PM
thedrill's Avatar
I have the same noise. Changed the compensator and tappets still have the noise. Going into the cam chest this weekend to check the runout. if its OK I will drive it till it rolls to a stop on the side of the road.
2012 Road Glide Ultra, 1978 Honda XL125, 1992 Suzuki DR350
thedrill is offline
Valve train noise 1st Sgt Engine Related 11 01-15-2018 05:12 PM
Valve train noise thread sfcusaret2004 Engine Related 12 08-29-2016 05:09 AM
Possible valve train noise rlaf75 Troubleshooting for Road Glides 20 05-24-2016 10:42 PM
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
Increase in Valve train noise when engine cold StriderJim Troubleshooting for Road Glides 8 10-07-2012 10:21 AM
