Are cams worth doing? - Road Glide Forums
post #1 of 24 (permalink) Old 05-14-2014, 08:40 PM Thread Starter
Bigfoots03hd's Avatar
Question Are cams worth doing?
I know it sounds like a stupid question but I'd really like to know cause I'm thinking about doing cams. Quick run down on my bike 2012 RG custom stage 1 done with Ventilator AC Rinehart slip ons decatted stock header but planning on changing. Bike runs good but would like just a little more out of it without going crazy. I was told do cams with a tuner and I'd get what I'm looking for I'm looking at SE 254E cams and I'll probably have the bike dynoed when it's all done. So give me your input and suggestions. Thanks
Bigfoots03hd is offline
post #2 of 24 (permalink) Old 05-14-2014, 08:59 PM
pat123's Avatar
It's night and day with the right cam. There's a lot of cams out there that will be better than the 254's.
Tman torque 555's
Andrews 57's
Andrews 48's
Woods 222's
Call fuel moto. They will point you in the correct direction.
pat123 is offline
post #3 of 24 (permalink) Old 05-14-2014, 09:04 PM
jimmyray11349's Avatar
absolutely...gained about 20hp and tq....oil temp dropped 25-30 degrees...on the downside dropped about 8 mpg
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #4 of 24 (permalink) Old 05-14-2014, 09:13 PM
You can get mild cams from Screaming Eagle, this will not cause warranty problems. Also mild cams will provide increased low end torque which is where most folks will take notice, and still provide excellent fuel mileage. A higher revving cam will provide more HP but you have to get that HP at higher RPMs. Ask you dealer. With a cam install you can get you ECM flashed which eliminates need for a tuner. But a tuner gives you the flexibility of different tunes/maps for your ECM. Yes, like mild, medium or hot chicken wings, cams are worth it.
grambo is offline
post #5 of 24 (permalink) Old 05-14-2014, 09:27 PM
tdkkart's Avatar
The factory cams are so choked by the emissions regs that the motor really doesn't even run right. There are some of the SE cams that run pretty decent, but not any of the "EPA approved" versions. The SE 204 that I have in my bike is an older design but runs very well, as does the 203 at slightly lower rpms. There are newer versions that are very close to these as well.
I would definitely go with a tuner rather than the download.
tdkkart is offline
post #6 of 24 (permalink) Old 05-14-2014, 10:05 PM
BDMastiff's Avatar
I agree.
Cams are the next logical step if you're trying to increase your performance. Be careful 'cause heads come next.
1996 Fatboy
BDMastiff is offline
post #7 of 24 (permalink) Old 05-15-2014, 06:32 AM
Either a Wood 222 or an Andrews 48, in order to have that big torque right up off the bottom to get that touring machine moving.
We'd suggest getting a hold Doc's Performance tuning in Mineola, Fla. also.
Scott
Hillsidecycle.com is offline
post #8 of 24 (permalink) Old 05-15-2014, 08:17 AM
Banned
A+ on the 48`s
hotrod is offline
post #9 of 24 (permalink) Old 05-15-2014, 08:39 AM
I love cams, just makes the bike sound & feel like a toy or a hot rod. Good luck resisting head work after that.
12 RGU Ember Red Sunglow
Heated Hammock seat, CVO bars
Decat, heated grips
billy t is offline
post #10 of 24 (permalink) Old 05-15-2014, 09:47 AM
Kylea's Avatar
What is the diffence between andrews 48 and 57? Thank you
Kylea is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
Are Saddlebag Lids Worth Doing?? 1BadGlide Audio 8 05-27-2013 01:17 PM
heading to va. ...doing the parkway this weekend slaterman5 Road Trip Discussions/Stories/Pictures 8 07-26-2011 07:29 PM
Re-doing an Anniversary Edition Bike Dead Bird Dog *General Road Glide Discussions/Pictures 8 11-02-2010 07:29 PM
Any 20%ers doing free shipping right now? jbrawkus *General Road Glide Discussions/Pictures 5 10-01-2010 01:29 PM
