Failed rings...extended warranty may not cover? - Road Glide Forums
post #1 of 22 (permalink) Old 05-17-2014, 07:52 PM Thread Starter
I bought a 2010 FLTRX from my dealer in Dec 2012. Third bike from them, 8 year relationship. Also bought a four year extended warranty.
About two weeks ago I noticed excessive oil consumption. Like 1.5 quarts in 300 miles. I took it in last week and was told the warranty would cover repairs labor and parts but not diagnostic time. They estimated 1-2 hours shop time to determine the problem. Fine, whatever.
Today they called me and said the rings failed. Then the bad news... since it was a used bike, ring failure is not covered. They recommended I call the extended warranty people. I did so, and was told that oil consumption on a used bike wasn't covered. I explained that the point of the warranty was to cover catastrophic mechanical failures while I was still making payments, and that the dealership assured me that the bike was covered from fender to fender (less brake pads, batteries and paint). He put me on hold and when he came back he said broken rings were covered, but not worn ones. He said the service write up was non specific, and that I should call the dealership.
I called the dealership back, and was told yes, the rings were broken, and that they felt "failed" and "broken" were the same thing. I asked them to sort it out with Extended Warranty.
At last contact the Dealership said Extended Warranty was sending out an inspector next Wednesday.
Anyone experience issues getting the extended warranty to kick in? My real beef is with the salesman that assured me I was covered as long as I did the services (I did) and didn't do anything crazy to the motor on my own (I didn't). There are no mode that would affect the motor aside from the PCV, which was on the bike when they sold it to me. The engine is stock, had 4500 miles when I bought it, and failed at 9900. If they don't honor it, I'm considering cancelling the rest of the warranty because 1) I'll need it to pay the repair bill with the refund and 2) it doesn't seem to be doing anything for me.
If I get hung out to dry I'll pack the bike up, take it elsewhere, eat the bill (and probably go big bore), and never set foot in the dealership again. I have other options. Whole thing was an unnecessary blood pressure spike for me.
pastryslayer is offline
post #2 of 22 (permalink) Old 05-17-2014, 08:28 PM
rageglide's Avatar
I don't use warranty's cuz I always void em... but, imo if you've got a good relationship with the dealer. good is relative of course, because you may think you have a good relationship, and the dealer may disagree... anyway, assuming they don't hate you.
Go in and talk to the guy you have the best relationship with and ask if he can help you out before you pull the bike outta there. You'll be paying them quite a bit for the diag part, and they won't release it as a pile of parts, so you'll pay for the partial assembly too.
The reality is a new set of rings and quick hone at this point is cheap. The costs are in all the work you've already committed to. That said, you didn't say how many miles are on the bike. But obviously boring your cylinders for a .010" oversize if necessary is going to cost the same as the "big" bore size 3.875". The pistons will cost marginally more than the next oversize piston... So IF you are at a point you have to go o/s, then it's no brainer to do the big bore. IF you have low mileage and can reuse your pistons the ring replacement is cheap...
Net of that is, if the relationship is important and you want to keep the warranty intact for other aspects of coverage, take a breath and have the non-catastrophic problem resolved.
2012 fltrx
rageglide is offline
post #3 of 22 (permalink) Old 05-17-2014, 08:34 PM
Easyryder01's Avatar
If the dealership really wanted then work they would assist you and get it covered. Yes a cash job to them is worth more than a warranty job but they don't even pay their mechanics what their supposed to receive either. Either way I believe the true test of loyalty to you would be to get the verbage on paper and get the part that's broken there for the adjuster to see if you follow what I mean ?
2017 RGS Velocity Red
Easyryder01 is offline
post #4 of 22 (permalink) Old 05-17-2014, 09:42 PM
Salesman will tell you anything. If your dealer & service dept. was worth a $hit he would get with ESP & get it straighten out.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #5 of 22 (permalink) Old 05-17-2014, 09:46 PM
That's if the salesman sold you an OEM warranty and not an aftermarket.
post #6 of 22 (permalink) Old 05-17-2014, 10:00 PM
I dont think you will have a problem. If the bike had 50k , that might be normal wear. At 9k , that much oil blow bye is not normal wear.
If the dealer wrote it up right the first time , it would have been approved.
What did the leak down test show ?
Big_gary is online now
post #7 of 22 (permalink) Old 05-17-2014, 10:43 PM Thread Starter
I may have understated the problem. According to the dealer, ring failure is the cause...but the pistons and cylinders are damaged and I'm looking at a $2,000 rebuild of the too end. Bike has 10k miles. Which is why if I have to pay for it I'll go big bore. Labor should be about the same regardless of displacement.
I will certainly give the dealership a chance to make it right, and I know exactly where I'll start. But if they blow me off...not one more penny.
ETA: no mention of a leak down test.
post #8 of 22 (permalink) Old 05-17-2014, 11:10 PM
I don't see how the ext. warranty company can deny payment then. Has nothing to do with the dealer.
post #9 of 22 (permalink) Old 05-18-2014, 09:57 AM
Never heard of broken rings at 9,000 mile on a stock 96" engine. I would say that with the mileage there was a mechanical problem far more serious then worn rings and the ESP should cover it.
You didn't mention if you have the HD extended warranty or a aftermarket extended warranty, which may make a difference in coverage.
If the rings are broken then there will be piston and cylinder wall damage which will result in a complete top end rebuild so this would be a good time to upgrade to the 103" BB and just pay the difference.
post #10 of 22 (permalink) Old 05-18-2014, 11:20 AM
Not even sure how ya'd break a ring, should be obvious though. If you move your bike to service eslewhere likely the "diagnostic time charged" wouldn't be reimbursed by ESP. And yes you can get your bike back in any stage of dis-repair, it's not theirs, just get all the parts loaded then say FU, if they don't do everthing to keep you then FUFU
reds4 is offline
Does extended warranty cover clutch cable jrbean1 *General Road Glide Discussions/Pictures 8 09-19-2016 07:50 AM
Engine/ fuel manag. And extended warranty GuyHD ECM/Fuel Management systems 2 09-07-2011 09:43 AM
Extended warranty?? ZachB *General Road Glide Discussions/Pictures 19 03-22-2011 05:21 PM
