My cam chain tensioner woes... - Road Glide Forums
post #1 of 12 (permalink) Old 05-18-2014, 11:19 AM Thread Starter
As some of you might know, I only just recently bought my first HD. I bought my 2001 RoadGlide in March with 39k miles on it from a local dealer. I do all my own maintenance and recently changed out all the fluids and filters. The oil that drained out was hideous. I've been doing some reading and got spooked reading up on this tensioner issue. So, I took it in to the dealer to get a look at the tensioners.
Holy hell.
From what the mechanic said, the front shoe is worn bad and the rear one isn't much better. In fact, he said the rear one has a small crack in it. They only had one of the the tensioners in stock and had to order the other one so I'm not going to ride the bike again until I can get it in on Saturday the 24th for them to get replaced. Dodged a bullet on this one. Damn
Is there much advantage in buying the SE cam plate with hydraulic tensioners? Do they last much longer than these spring loaded ones?
Sent from Motorcycle.com App
Slyguy41 is offline
post #2 of 12 (permalink) Old 05-18-2014, 01:54 PM
From what I have read the newer hydraulic seem to last longer but I don't know if they have been around enough miles to know for sure.
If they are taking yours down for new tensioners have them check your crank run out while they have it apart you may be able to switch to a gear drive which removes any future problems from the tensioner issue .
Eagle is offline
post #3 of 12 (permalink) Old 05-18-2014, 02:05 PM
staush's Avatar
Tensioners
Unless yours were changed at about 25k, the old material on those shoes was crap. The new material they use now is 5 times better. It would probably be worth the money and worry to change to hydraulics with the new material. probably wouldn't have to think about them for another 40k.
staush is offline
post #4 of 12 (permalink) Old 05-18-2014, 02:58 PM
You could also go with tensioners from a company called Cyco Gasket. They make a very good tensioner for a cheaper price than MOCO. I personally went all out and had the S.E. hydrolid tensioner plate installed. It also comes with a new oil pump that has a higher rate of flow. Twinn Camm 88 engines should put out about 32 psi at 2000 RPM once warmed up. If you have much lower psi you should consider the S.E. hydrolic cam tensioner kit. It is more money though.
grambo is offline
post #5 of 12 (permalink) Old 05-18-2014, 03:30 PM
May want to think about these from Zippers:
http://www.zippersperformance.com/pr...ensioners.html
I installed these about 14k ago and been very happy.
post #6 of 12 (permalink) Old 05-18-2014, 03:48 PM Thread Starter
I'm seeing about 35psi of oil pressure at 2K rpm. I'm considering the hydraulic unit and I'd like those shoes to have a tougher material for sure...
Slyguy41 is offline
post #7 of 12 (permalink) Old 05-19-2014, 12:25 PM
You would be much better off doing the cam plate upgrade with hydraulic tensioners. There are a lot of bikes out there that have 50,000 miles + and are still running the same hydraulic tensioner shoes.
post #8 of 12 (permalink) Old 05-19-2014, 12:37 PM
The rear usually wears quicker than the front. If there is a crack either replace or go with the up[grade set up. I did the upgrade on both my pre 07 bikes and had no issues with either.
My new bike comes with whatever is in the 13 and should not be an issue. We'll see when I pull the cam cover in a few months.
HogPro is offline
post #9 of 12 (permalink) Old 05-19-2014, 04:50 PM
mocotom's Avatar
The Cyco pads are a good choice if your on a budget as they are much better than the material on the stock pads. If you ever thought of changing cams then go to the gear drive, your 2001 will most likely have a crank within spec.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #10 of 12 (permalink) Old 05-24-2014, 02:24 PM Thread Starter
ImageUploadedByMotorcycle1400955692.058264.jpgImageUploadedByMotorcycle1400955731.043478.jpg
At the dealer getting them changed out.
Replacing all the bearings while they're into the motor too...
Slyguy41 is offline
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 08:47 AM
Cam Chain Tensioner Help Z-SHARK Engine Related 3 06-01-2013 08:34 PM
cam chain tensioner cyclejuice Engine Related 7 05-30-2013 05:53 PM
Hydraulic chain cam tensioner kit ohd24 Engine Related 7 06-30-2012 08:24 AM
Cam chain tensioner question SKULLZ *General Road Glide Discussions/Pictures 5 05-14-2011 03:29 PM
