performance clutches - Road Glide Forums
post #1 of 19 (permalink) Old 05-18-2014, 12:17 PM Thread Starter
jaysrgu's Avatar
after the winter build the trq and hp increase has been damn fun,clutch is starting to slip 4-5 gear shift and 5-6 gear shift,also when first started it slightly lurches forward,im thinking the lurching is warped discs and that I need to upgrade,currenty running 2012 stock clutch with screamin eagle diap spring,interested in what else is out there and others experiences,lots to choose from
jaysrgu is offline
post #2 of 19 (permalink) Old 05-18-2014, 01:14 PM
Hullhorr's Avatar
I installed the Rivera Primo last summer and couldn't be happier. I believe the Barnett is very similar. I was torn between the two and did the eanie, meany, miney, moe to decide.
The one thing to keep in mind is the clutch pull will be harder than with the stock clutch.
The other option is the Variable Pressure Clutch. This is added to your existing clutch and helps with a slipping clutch without adding any difficulty of clutch pull pressure. Whether or not this will be a good option depends on what engine mods you did. If your over 110-115 TQ. I would suggest something like the Rivera Primo.
2009 FLTR MOP
Hullhorr is offline
post #3 of 19 (permalink) Old 05-18-2014, 02:39 PM
ENG25TRK's Avatar
I'm running the Barnett clutch. Agreed with Hullhorr, the pull is much harder. Shifting is nice and smooth, responsive. I'd recommend it if you don't mind the hard pull on the clutch lever.
ENG25TRK is offline
post #4 of 19 (permalink) Old 05-18-2014, 03:38 PM
Banned
nothing better than a BANDIT clutch
hotrod is offline
post #5 of 19 (permalink) Old 05-18-2014, 03:43 PM
sloride's Avatar
I have the Rivera Pro Clutch on my RGC and love it, Lloyd at V-Twin Solutions installed it and the clutch pull is no stronger than stock.
sloride is offline
post #6 of 19 (permalink) Old 05-18-2014, 05:17 PM Thread Starter
jaysrgu's Avatar
I have the se diap spring which is firmer then stock,i run a bandit in my modified drag bike along with energy one plates,im actually thinking of running energy ones upgrade with more plates,guys that told me about it love them
jaysrgu is offline
post #7 of 19 (permalink) Old 05-18-2014, 05:59 PM
I have the SE race clutch, pull is a bit harder, but there's no such thing as slip.
Sent from my SPH-L710
post #8 of 19 (permalink) Old 05-18-2014, 08:59 PM
Just put a primo pro in my bike and put 200 miles on today, couldent be happier no more slip pull is almost to easy, lighter then stock with with a screaming eagle dia. Only caution I have is that the counter weights will hit on stock cover if it has a 103 badge in it, replaced with a standard cover and have no issues.
drnovaman is offline
post #9 of 19 (permalink) Old 05-18-2014, 09:50 PM
SE spring is 320 psi and with a AIM Vp lock up stock plates will work great no issues.
QUOTE=jaysrgu;1883657]after the winter build the trq and hp increase has been damn fun,clutch is starting to slip 4-5 gear shift and 5-6 gear shift,also when first started it slightly lurches forward,im thinking the lurching is warped discs and that I need to upgrade,currenty running 2012 stock clutch with screamin eagle diap spring,interested in what else is out there and others experiences,lots to choose from[/QUOTE]
DragoBikeWorks is offline
post #10 of 19 (permalink) Old 05-18-2014, 10:16 PM
jack6hd's Avatar
[/QUOTE]
I run this set up and it works flawlessly.
2015 FXDL 2nd best HD on road
jack6hd is offline
07-16 clear derby cover by Barnett Clutches Lu Parts for Sale 12 10-19-2017 02:34 PM
Barnett Clutches Hdclw99 Parts for Sale 1 05-30-2017 05:45 AM
Transmssion or Clutches Hdclw99 Engine Related 2 02-14-2017 06:00 AM
Something I Learned Today About Hydraulic Clutches lil chief *General Road Glide Discussions/Pictures 3 05-14-2016 10:59 PM
