GMR Compensaver oiling tray - Road Glide Forums
post #1 of 15 (permalink) Old 05-25-2014, 06:38 AM Thread Starter
FLTR2008Trike's Avatar
Thumbs up GMR Compensaver oiling tray
I received my GMR Compensaver oiling tray to install with the SE Compensator I will be getting next month and installing. This is a robust cast tray with something I didnt read about before. GMR is gluing a very strong magnet in the tray to catch any ferrous metal fragments before they get into to the Comp bore.
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #2 of 15 (permalink) Old 05-25-2014, 09:38 AM
tdkkart's Avatar
Too bad nobody can come up with a decent compensator, rather than a bunch of band-aids for the OEM POS.......
tdkkart is offline
post #3 of 15 (permalink) Old 05-25-2014, 11:24 AM
Yea, 'guess I'm going to have to treat compensators like brake pads ~ a wear item...
HeatWave is offline
post #4 of 15 (permalink) Old 05-25-2014, 01:24 PM
tdkkart's Avatar
Those are some damn'd expensive brake pads.......
And it'd be one thing if it was a 117" hotord motor, but there are 96 and 103" STOCK motors. My 103 has less than 20,000 miles and compensator rattles and clangs every time I shut the bike off. Ridiculous.
tdkkart is offline
post #5 of 15 (permalink) Old 05-26-2014, 09:48 AM Thread Starter
This Compensaver oiling tray will extend the life of the Compensator
post #6 of 15 (permalink) Old 05-27-2014, 06:38 AM
Evo Industries offers a non-comp sprocket, that way, no jee-jaws are needed.
Scott
Hillsidecycle.com is offline
post #7 of 15 (permalink) Old 05-27-2014, 11:37 AM Thread Starter
Thumbs up
Scott
How is it you recommend a non comp unit that can ruin the spline shaft on a stock flywheel assembly as well as do possible damage to the transmission shaft??
Palmer, your such a wealth of information. Im glad your banned from 2 other forums.
post #8 of 15 (permalink) Old 05-27-2014, 01:06 PM
I agree 110%, it is ridiculous! Even more so, I'm thinking of treating lifters as a wear item also...
'Am a bit leery of those sprockets (instead of compensators).
'Haven't seen any reliable, long term (high mile) feed back on the sprockets.
Like you said, Compensators (and lifters) are pretty expensive wear items, but no where near as expensive as Crankshafts and Cases...
BTW, had 2 failures on the '09 SERG, front rod bearings discovered during tear down for Stage III at 9.5k (stock, just pipes and chip) and front intake lifter (took out whole engine) at 21.5k, maintained with an open check book, and I don't beat on it.
HeatWave is offline
post #9 of 15 (permalink) Old 05-28-2014, 06:52 AM
You can be glad, sad, mad, or even attempt to be bad, but your thoughts on anything getting ruined are totally ludicrous.
Just simply contact Evo Industries. Period.
Absolutely no different whatsoever if someone was running a belt drive...........something you may consider before you post info that is incorrect.
Scott
post #10 of 15 (permalink) Old 05-28-2014, 07:29 AM Thread Starter
Scott
I'm very glad your banned due to your repeated attempts to discount others who offer something you dislike or tell you your wrong, again.
To your wise and so experienced response, let's look at the hollow splined output shaft and the press fit crank pin in a stock flywheel assembly. It's already a weak setup and your advise is to remove a setup that does give some cushion to installing a setup that provides none.
Sorry but you might think your a guru of the NY mountains, but it doesn't pass the smell test with many of us
Top oiling a V twin Jacksprat56 Fluids and Lubricants 9 05-09-2018 10:30 AM
I'm getting a compensaver*** HogPro *General Road Glide Discussions/Pictures 42 12-18-2014 10:40 PM
13 rgu gmr 577 cam Boomertx Dyno Results 2 05-19-2014 11:26 AM
Anybody tried Compensaver? 1 HD ULTRA Engine Related 19 12-03-2013 07:50 PM
