Motor cuts out - Road Glide Forums
post #1 of 15 (permalink) Old 05-25-2014, 09:01 AM Thread Starter
Motor cuts out
Hi Folks, my 09 RG motor has been cutting out when out for rides. I will be out cruising usually 30-60 mph and then just a quick sputter/backfire and motor will pick up again. I can feel the backfire and notice the radio will power down then on again which makes me think it is electrical. Very random and sometimes happens and sometimes not so I think it would be tough to diagnose or tell a shop to fix as it may not happen for them. I have checked most obvious connections, battery, ECM. I have been playing around with maps in my Powervision and have even taken the PV out to see if that was the but still happens with it removed. Any suggestions?
TIA
mpowered is offline
post #2 of 15 (permalink) Old 05-25-2014, 10:05 AM
Are there any DTCs ???
post #3 of 15 (permalink) Old 05-25-2014, 10:17 AM
Are there any codes? Is it a skip or misfire?
post #4 of 15 (permalink) Old 05-25-2014, 10:22 AM Thread Starter
Ok going to check codes and pushed od reset button and held for 10 secs, now nothing, no power when I turn ignition? Did I put it in travel mode?
mpowered is offline
post #5 of 15 (permalink) Old 05-25-2014, 10:28 AM
Did you read the stickys in the troubleshooting section on how to access your DTCs?? Holding the reset button for 10 seconds is not the way to check for DTCs.
post #6 of 15 (permalink) Old 05-25-2014, 10:43 AM Thread Starter
I realize that. I thought I remembered how to check DTC codes so went to garage and pushed odo reset and held for 10 seconds and now no lights power, ignition etc. What did I do?
mpowered is offline
post #7 of 15 (permalink) Old 05-25-2014, 11:10 AM Thread Starter
It is more like a misfire.
mpowered is offline
post #8 of 15 (permalink) Old 05-25-2014, 12:40 PM Thread Starter
Now I get codes 1353 and 1356
mpowered is offline
post #9 of 15 (permalink) Old 05-25-2014, 12:50 PM
That is the front and rear cylinders having no combustion. That is usually a spark plug or spark plug wire problem, I wouldn't think it is coil related because there is no DTC referring to the coil. You could also have a ignition switch or run/stop switch shorting out.
post #10 of 15 (permalink) Old 05-25-2014, 01:25 PM Thread Starter
Thnx Ironmark, It looks like I had a short somewhere from the battery. I have checked all my grounds and retightened the connections for the positive cable to the fuse box and motor. I did pull the plug wires off, inspected, cleaned and re-connected. I will take for a test ride and report back.
mpowered is offline
Bike cuts out Daddy7734 Tech Area 7 02-01-2019 08:48 AM
Radio volume cuts out when bike is started denharrigan Audio 0 03-25-2017 04:28 PM
Cuts out at Higher RPM's goplay Tech Area 10 03-21-2017 04:37 PM
Radio cuts out on engine start? dbbarton00 Troubleshooting for Road Glides 4 02-18-2012 09:02 PM
cuts out after warmed up... chuckp *General Road Glide Discussions/Pictures 1 03-05-2011 09:42 PM
