More Power II - Road Glide Forums
post #1 of 6 (permalink) Old 05-25-2014, 10:57 PM Thread Starter
More Power II
After the negative posts on the SE Pro Stage III kit I visited with my buddies at Strokers USA and got some new suggestions. They recommend a S&S 106 Hot Setup kit with 585 cams. It's about $400 more than the SE kit because the tuner doesn't come with it. Any thoughts out there on this kit?
Thanks for the help I appreciate the help
RR
Red Rider is offline
post #2 of 6 (permalink) Old 05-26-2014, 07:23 AM
mocotom's Avatar
Much better choice!
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 6 (permalink) Old 05-26-2014, 07:33 AM
sloride's Avatar
Originally Posted by mocotom View Post
Much better choice!
X2
sloride is offline
post #4 of 6 (permalink) Old 05-26-2014, 07:38 AM
BlownBagger's Avatar
Get ahold of [email protected] he sells the snot out of those S&S 106 kits.
_
BlownBagger is offline
post #5 of 6 (permalink) Old 05-26-2014, 07:44 AM
Banned
have your cylinders bored to 107",much cheaper than the S&S kit.the 585 cams work very well with a 107" build
hotrod is offline
post #6 of 6 (permalink) Old 05-27-2014, 06:35 AM
We have been boring those cylinders to 107" here since 2007,(and boring H-D cylinders for almost 30 years) with final hone with a 400 grit stone, then plateau honed, with both cylinder base and head gasket surface's prepped.
Complete with all the Cometic gaskets needed, ring end gaps set, rings installed on the pistons.............only $600.00
88-98" same/same.
On a side note we have these on 4 continents..........
Scott
Hillsidecycle.com is offline
How many more? How many more? Uncle Fuzzy *General Road Glide Discussions/Pictures 32 04-11-2014 01:32 PM
Power Vision Map for 103 RG Stage II carcass Map Section 0 05-17-2012 12:41 PM
