best way to remove head gasket residues - Road Glide Forums
post #1 of 18 (permalink) Old 05-26-2014, 05:13 PM Thread Starter
Hi I pulled my heads to install compression releases and need to clean the head gasket surfaces. What's the best way to get them clean without getting junk down in the cylinders.
Thanks.
Reddobe1 is offline
post #2 of 18 (permalink) Old 05-26-2014, 06:29 PM
Banned
be very carefull
hotrod is offline
post #3 of 18 (permalink) Old 05-26-2014, 07:28 PM
sj01fltri's Avatar
I get spray gasket remover spray it into any metal container then use a small brush to apply to cly,first i stuff the clys full of paper towels to keep any residue from getting in clys,then using a small putty kinfe lightly scrape off gasket matrial,this method hasnt failed me yet.
sj01fltri is offline
post #4 of 18 (permalink) Old 05-26-2014, 07:29 PM Thread Starter
Other than that is there a method that works better than the others? Some type of scrapper or solvent. I'm thinking maybe a plastic scrapper that won't damage the mating surface of the cylinders and heads.
Reddobe1 is offline
post #5 of 18 (permalink) Old 05-26-2014, 07:31 PM
Roll the engine over until the piston is at the top of the jug. I used a brass brush then a medium honing stone. You only have to worry about the area the head gasket covers.
post #6 of 18 (permalink) Old 05-26-2014, 07:56 PM
Banned
you've got the right idea.gasket remover isn't a good idea because it`ll eat thru the powder coat quicker than the gasket & ide think a wire brush would make more of a mess than the scraper.just use the small plastic scraper (spray alittle WD-40 on the cylinder wall,then bring the piston to TDC),after you get the gasket residue off,slowly bring the piston down about 1.5",any gasket material that dose get in the bore will stick to the WD-40,just wipe the bore with a clean engine wipe and you`ll be OK
hotrod is offline
post #7 of 18 (permalink) Old 05-26-2014, 08:11 PM
sj01fltri's Avatar
Thats why you use a small brush such as a acid brush.Leave it set for about 15 min takes very little effort to remove.
post #8 of 18 (permalink) Old 05-26-2014, 10:38 PM
rageglide's Avatar
patience, a plastic scraper and some carb cleaner carefully applied. carb cleaner has same ingredient as paint stripper so you've got to be careful.
2012 fltrx
rageglide is offline
post #9 of 18 (permalink) Old 05-27-2014, 01:53 AM
adrenilinecrash's Avatar
There isn't a good way. Its just not a fun or easy job.
02 FLTRI
15 FXDL
adrenilinecrash is offline
post #10 of 18 (permalink) Old 05-30-2014, 10:34 PM
Thumbs up
Thanks.
I just went down this road myself....I found the best way is to have them machined perfectly flat and smooth at a machine shop used to harley heads. The have a tendency to warp just a tiny bit due to the fact they are aluminum so a very light mill, just a surface mill really, makes sure they are flat and will seal correctly and are squeaky clean. Money well spent IMHO since they are off and all.....
stogieluvr60 is offline
Best Wax to remove light swirls by hand OKBigD Paint & Bodywork Section 10 04-18-2014 07:43 AM
Head Gasket Deadstroke Engine Related 16 08-31-2013 06:17 PM
Rear cylinder head gasket leak... Johnzz1420 Engine Related 6 08-20-2013 06:41 PM
Best way to remove console insert, '13 FLTRU HellInABucket *General Road Glide Discussions/Pictures 11 07-16-2013 10:18 AM
