oil temp...how high??? - Road Glide Forums
post #1 of 6 (permalink) Old 05-27-2014, 10:24 AM Thread Starter
Darreldanger's Avatar
How high have you guys run your oil temp, either accidental or on purpose??? I have a 2012 RGC and when my wife and I ride it's common to see 235 on the freeway and it's only the month of may...
Darreldanger is offline
post #2 of 6 (permalink) Old 05-27-2014, 12:00 PM
235 is right where it should be and it will rise as the ambient temp rises in the summer. I have seen 270 to 280 before and never had a problem. I use to run a HD 6 row oil cooler which broke on me so it is in the trash and now I run a 10 row Jagg which is much better than the HD oil cooler.
Run a good full synthetic oil in the engine because it will not break down with the higher engine temps.
post #3 of 6 (permalink) Old 05-27-2014, 01:23 PM
hd4cruzin's Avatar
+1 ^
2012 FLTRX BBP
hd4cruzin is offline
post #4 of 6 (permalink) Old 05-27-2014, 07:43 PM
BlownBagger's Avatar
The most I've seen this year has been 190 degrees
_
BlownBagger is offline
post #5 of 6 (permalink) Old 05-29-2014, 06:25 AM
Solid advice from ironmark.
Scott
Hillsidecycle.com is offline
post #6 of 6 (permalink) Old 06-02-2014, 10:17 AM
Oil Bud
235 would be normal with the stock oil cooler. I run the Oil Bud Oil Cooler and on an 80 degree plus day my oil temp stays at 200 on the freeway and rarely goes over 210 in city traffic.
easybiker is offline
Engine oil temp? At what temp do you pull over? Mountainman Fluids and Lubricants 35 07-07-2015 04:47 PM
High temp and pinging PVC ThunderAO ECM/Fuel Management systems 13 07-14-2013 07:36 PM
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
Looking for a high temp semi/satin black RaceBizz Paint & Bodywork Section 1 11-18-2011 08:00 AM
Lower your oil temp by changing your oil...??? dklanecky Do-IT-Yourself 14 07-07-2010 10:29 PM
