527 red shift - Road Glide Forums
post #1 of 4 (permalink) Old 05-27-2014, 06:14 PM Thread Starter
527 red shift
I had Red Shift cams installed on my bike 2011 RGU 103
527 cams S&S push rods Fueling lifters zippers chain tensioners and oil valve
K&P oil filter Reinhart mufflers Rush header pipe and Thunder max tuner
I was told the 527 where to be a quiet cam .had valves adjusted all diff ways
1st by spec 3 3/4
2nd 4 1/4
3rd bottom and 4 flats
old lifters and new lifters same tap sounds like a motor with little oil and I am running Lucas 50w syn with 38psi and 15psi at idle hot
Anybody using 527 cams and having this problem. I can only play my radio so loud
hd2011 is offline
post #2 of 4 (permalink) Old 05-28-2014, 11:50 AM
Looks like you may be over adjusting the pushrods. In most cases 2 3/4 to 3 1/4 turns is all thet is required. It depends on how many threads per inch you have on the pushrod some pushrods are 16 threads per inch and some are 24 threads per inch.
I may be wrong but I think the S&S pushrods are 24 threads pre inch and somewhere around 18 flats or 3 turns should get you in the correct range.
You should turn the engine over until the cam is on the base circle then adjust the lose pushrod by hand until it makes contact with the rocker and the lifter, you can tell because you can not move the pushrod up or down.
Then do the 3 turns on the pushrods and after approx 10 minutes you should be able to spin the pushrod by hand.
post #3 of 4 (permalink) Old 05-28-2014, 12:20 PM Thread Starter
The specs where from fueling and red shift. Zippers specs all the way down than 4 flats Do you any body running 527 cams and are they quiet
Thanks for the input
hd2011 is offline
post #4 of 4 (permalink) Old 05-28-2014, 12:29 PM
Your lifters are bottomed out. The lifter has approx 1 inch of travel and you should be set at the center of the lifters travel, this will allow the lifter to pump up and pump oil to the top end of the engine.
If the lifter is bottomed out it will not pump the oil to the top of the engine causing top end noise and possible engine damage.
The proceedure I posted is the correct proceedure to adjust adjustable pushrods according to HD and S&S so give it a try.
Red Shift 525 cams TRUBlue Engine Related 12 09-06-2012 10:25 PM
