Barnett Scorpion Clutch - Install Question - Road Glide Forums
post #1 of 1 (permalink) Old 05-30-2014, 11:24 AM Thread Starter
Anyone install one of these and get the hub nut tight WITHOUT buying/using the Barnett Clutch lock plate tool?
The tool is only $25 but I don't have one and trying to get this thing finished up.
Barnett pressure plate is solid, Harley one has a hole in the middle.
Harley you can put a socket on the hub nut with the plate on and the clutch hub and basket lock together because the clutch is engaged.
Barnett you need the pressure plate off to get access to the hub nut which means the basket and hub spin because the clutch cant engage without a pressure plate on there.
2011 RG Custom, Screaming Eagle Stage IV (260 Cam), Barnett Scorpion clutch, Hayden M6, Baker DD7, V&H Throttlepak, V&H Power Duals w/Hi-Output Slipons
115.4 ft-lb & 122.7hp : 1/4 Mile 12.542 @ 105.99 w/stock clutch and transmission
gbourdon is offline
Barnett clutch springs Trak350 Engine Related 3 06-06-2014 11:26 PM
Barnett Clutch Mike Jesse Engine Related 0 03-10-2012 11:14 PM
Barnett Scorpion Clutch Ruggerbk Tech Area 0 02-24-2012 07:49 PM
Barnett clutch RoadGlide0611 *General Road Glide Discussions/Pictures 8 10-09-2011 08:12 AM
For sale: New +8 Barnett clutch cable SickRick Classifieds Archive (3 months old+) 0 09-19-2011 10:58 AM
