Fuel leaking from quick disconnect fitting HELP!! - Road Glide Forums
post #1 of 11 (permalink) Old 05-31-2014, 05:32 PM Thread Starter
JJSW1283's Avatar
So Im putting my bike back together from my stereo install. Put the tank back on, plug in quick connect gas fitting and it starts leaking. I disconnect it and there is still a drip. I look up into it with a flash light and see an O ring. End up draining the tank completely and turning the tank upside down on my workbench. Replace O ring, put back on and still leaking. Take back off and fiddle with the check valve. End up pulling it straight out, looked fine, reinsert. I have never messed with these fittings other than connecting and disconnecting so I know nothing about them. So I have another o ring in place, and it leaks. But only when disconnected. When I connect the fuel line, it doesnt leak, but now bike wont start. Is there a right or wrong way to have the check valve in place?? Why is it leaking when the line is disconnected?
JJSW1283 is offline
post #2 of 11 (permalink) Old 05-31-2014, 06:28 PM
Banned
theres alittle O ring in there,just get a new one and you`ll be fine
hotrod is offline
post #3 of 11 (permalink) Old 05-31-2014, 06:50 PM Thread Starter
JJSW1283's Avatar
I know. There are two actually. I replaced the one that was ripped. Idk how to tell if I could have put the check valve in incorrectly.
JJSW1283 is offline
post #4 of 11 (permalink) Old 05-31-2014, 11:28 PM Thread Starter
JJSW1283's Avatar
I couldn't find an exact size O ring. They one I put in was a little fatter. I read the O rings used for the drain plugs were the same size. Guess I'll try that.
JJSW1283 is offline
post #5 of 11 (permalink) Old 06-01-2014, 08:26 AM
Banned
they are
hotrod is offline
post #6 of 11 (permalink) Old 06-01-2014, 10:04 AM
BlownBagger's Avatar
You need to open up the top of your tank and see what is going on as far as it not starting.I found out the hard way I flipped mine on its side once and float for the sending unit fell off .You probably have something disconnected after you flipped it upside down.Sometimes these fittings will leak until you start the bike and get some fuel pressure in the line.
_
BlownBagger is offline
post #7 of 11 (permalink) Old 06-01-2014, 10:57 AM
As soon as the key is turned on the fuel line will pressurize that is if the fuel pump is working correctly. The bike will not start without the fuel line being pressurized.
I know you tried this but just in case you didn't you have to pull down the quick disconnect fitting on the tank for it to seat correctly.
I have never had a problem with the fuel line or the quick disconnect fitting so keep us filled in on how you fixed it
post #8 of 11 (permalink) Old 06-02-2014, 06:46 AM
Not an uncommon issue, after pulling the tank.
WD-40 helps in this situation.
Scott
Hillsidecycle.com is offline
post #9 of 11 (permalink) Old 06-04-2014, 10:32 PM Thread Starter
JJSW1283's Avatar
Got the leak fix and bike is back together and running. Bought an used this tool and it made things alot easier
JJSW1283 is offline
post #10 of 11 (permalink) Old 06-05-2014, 11:37 AM
So the leak was in the O rings and you used this tool to replace the O rings correctly??
Fuel quick disconnect help 10th Mountain Troubleshooting for Road Glides 13 08-24-2018 09:15 PM
Fuel line Quick Disconnect jnd42697 Do-IT-Yourself 9 04-09-2013 05:53 PM
Lower Fairing Quick Disconnect Kit Yesca Equipment-RG 13 07-23-2012 07:15 AM
Tourpack Speaker Quick Disconnect Options Illiniroads Audio 5 03-06-2012 10:36 PM
RGU Hard bag locking quick disconnect problem ichiban Road Glide Specific Discussions 14 10-10-2010 09:45 PM
