Barnett clutch springs - Road Glide Forums
post #1 of 4 (permalink) Old 06-06-2014, 12:12 PM Thread Starter
Trak350's Avatar
Just going to throw an FYI out here. I contacted Barnett to get definitive information on there clutch springs because I have been thinking of making a change to the clutch due to the lever pull (i miss easy pulls). Anyway the Barnett standard spring is around 350lbs and their heavy duty spring is around 450lbs. So for those of us hanging in the low 100's for torque and HPs the Barnett standard may be an option.
"Be polite, be professional, but have a plan to kill everybody you meet." Gen. James "Mad Dog" Mattis (USMC)
Trak350 is offline
post #2 of 4 (permalink) Old 06-06-2014, 05:26 PM
Ohiobellboy's Avatar
I'd have to look and see what the stock one that came out of my 110. I took it out and put the AIM 480 in it when I did my Clutchwiz. Pushing 116 on the torque and that heavier spring seems to help.
sent by my Droid using a TapaTalk knock off app!
A.K.A OBB
Ohiobellboy is offline
post #3 of 4 (permalink) Old 06-06-2014, 09:30 PM
Yes.
We use/stock the heavy duty's here.
Also combined with a VPC92T, that will hold onto 150/150.
Scott
Hillsidecycle.com is offline
post #4 of 4 (permalink) Old 06-06-2014, 11:26 PM Thread Starter
Trak350's Avatar
After reading other threads on here and other forums I just wasn't sure what the pull was of the Barnett HD spring in my bike. I don't believe I need more then 380lbs for my setup and didn't want to spend another 200-300 bucks on a VPC. Knowing I have the 450lbs now makes me believe I can downgrade to the standard 350lbs spring which is heavier then the 330lbs OEM without worry of slippage. I have already ordered the standard spring and will install it next weekend. I will post my findings.
Trak350 is offline
Hot Springs, Pig Trail, Eureka Springs weekend ride throttles&triggers Road Trip Discussions/Stories/Pictures 2 09-08-2014 09:49 PM
Barnett Clutch Mike Jesse Engine Related 0 03-10-2012 11:14 PM
Barnett Scorpion Clutch Ruggerbk Tech Area 0 02-24-2012 07:49 PM
Barnett clutch RoadGlide0611 *General Road Glide Discussions/Pictures 8 10-09-2011 08:12 AM
For sale: New +8 Barnett clutch cable SickRick Classifieds Archive (3 months old+) 0 09-19-2011 10:58 AM
