Vibration - Road Glide Forums
post #1 of 8 (permalink) Old 06-09-2014, 12:46 PM Thread Starter
Vibration
2011 RGU 2800 rpm and up start to get vibration 2,3,4 gear 5th and 6th
gear over 3000 rpm the vibration is all through the bike. At 85 mph my head shakes. Could the compensator cause this. Tires new and balance
Bike did run smooth at high speeds 80 to 105 know problems Any Ideas
hd2011 is offline
post #2 of 8 (permalink) Old 06-09-2014, 01:39 PM
PGR
PGR's Avatar
Easiest and cheapest place to start is plugs and wires. My wife had a bad plug wire, massive corrosion, and it caused exactly what you describe. I changed her plugs, and while I was plugging in the front wire, it felt "different". Looked inside the boot, and it looked like a corroded battery. New wires, and her bike runs really smooth now.
Ron..........................
PGR is offline
post #3 of 8 (permalink) Old 06-09-2014, 03:22 PM Thread Starter
Thanks but plugs new and wires good was set up on dyno
hd2011 is offline
post #4 of 8 (permalink) Old 06-09-2014, 03:36 PM
PGR
PGR's Avatar
Then the vibration should have happened on the dyno. Maybe the tech wasn't that good if he didn't notice the vibration.
PGR is offline
post #5 of 8 (permalink) Old 06-09-2014, 03:44 PM
Sounds like it could be a tranny or clutch bearing starting to go bad.
It may be possible that the compensator could cause this if the nut holding the compensator on backed off, but you should have had some other symptoms if that was the case.
Also you should check the rear pulley bearing if the bearing goes out on the rear pulley it will cause vibrations. Check wheel bearing too.
post #6 of 8 (permalink) Old 06-09-2014, 04:27 PM
waynemags's Avatar
motor mount
waynemags is offline
post #7 of 8 (permalink) Old 06-10-2014, 12:14 PM
rageglide's Avatar
Could also be:
- the tune
- motor mount, damage or loose
- loose or broken exhaust mount
- wheel bearings
- inner primary bearing
- overly tight primary chain
- shifted flywheels
tire vibration is usually fairly low frequency, about 60hz around 70mph.
2012 fltrx
rageglide is offline
post #8 of 8 (permalink) Old 06-14-2014, 05:49 PM
FLTR2008Trike's Avatar
Originally Posted by rageglide View Post
Could also be:
- the tune
- wheel bearings
- shifted flywheels
+1 With what is listed. Check the rear muffler isolator bushings for the exhaust. Could be the rubber isolators are shot or have vibrated out
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
Windshield vibration acexp02 Troubleshooting for Road Glides 8 06-02-2011 02:54 AM
bad vibration on the decel!!! Help!!! shimo Troubleshooting for Road Glides 12 05-31-2011 06:29 PM
Bag vibration NakedSnowman Troubleshooting for Road Glides 3 05-09-2011 01:53 PM
Idle vibration / cylinder unloading? hilltoptim *General Road Glide Discussions/Pictures 10 04-25-2011 11:59 AM
Floorboard Vibration jcanrun *General Road Glide Discussions/Pictures 4 03-14-2011 03:04 PM
