Case clearancing - Road Glide Forums
post #1 of 5 (permalink) Old 06-11-2014, 08:28 PM Thread Starter
Olskoo's Avatar
Case clearancing
I have a 2003 motor , just had a stroker flywheel put in with CP 10.25 107 pistons. 500 miles later piston are scored on the front of the front jug and rear of the rear. Mechanic said that on the 03 cases they need to be clearaced to run these pistons and that's what caused the damage is that true??
Olskoo is offline
post #2 of 5 (permalink) Old 06-12-2014, 06:16 AM
Certainly at the point of installing, that needs to be checked.
Scott
Hillsidecycle.com is offline
post #3 of 5 (permalink) Old 06-13-2014, 06:00 AM
If the bores were tight, the skirts would/should show signs of grabbing/smearing the skirts on both sides, not just the thrust side.
Something is funky, thats for sure.
Scott
post #4 of 5 (permalink) Old 06-13-2014, 09:54 AM
No way exp as much as Hillside, MOTO though..juggs are just the enclosure, for compression chamber for the proper fitment da da... Why just the '03 if the bottom end or travel bore was correct? So they know it's an '03 but the mating surfaces could give a sht
reds4 is offline
post #5 of 5 (permalink) Old 06-22-2014, 12:05 PM
Banned
have your guy explain (is he the one who built the motor?) theres no case clearancing needed for any 3.935" big bore kits on 2003`s or any other TC
PF120 is offline
Engine case cleaning. Mike Jesse *General Road Glide Discussions/Pictures 16 12-04-2014 11:42 PM
2011 FLTRUSE CVO Engine Case Paint Problems Cappoman Road Glide Specific Discussions 17 09-24-2011 09:27 PM
Top case lights billy t Road Glide Specific Discussions 2 08-05-2011 09:41 PM
In Case Of Emergency Nino General Off-Topic Discussions 3 06-12-2011 01:47 PM
WTB: Basket Case Sporty/Evo Defy Classifieds Archive (3 months old+) 7 04-26-2011 01:30 PM
