Thinking about changing cams, Lifters and Pushrods - Road Glide Forums
post #1 of 15 (permalink) Old 06-16-2014, 02:05 AM Thread Starter
I'm thinking about changing Cams in my 13 RGU. Been looking at fuel Moto, Andrews, S&S & Fueling. Plan on having head work done and raising compression to over 10.1 want to burn pump ethyl gas. Have stage one on the Bike. Don't want a lot of noise coming from the cam chest.
Can anyone give recommendations. On how to proceed?
Straitline is offline
post #2 of 15 (permalink) Old 06-16-2014, 06:40 AM
If looking for stout low-mid range power, then either an Andrews 48, or a Wood 222 are 2 that come to the top of the list.
We always have all in stock to allow easy installation.
Scott
Hillsidecycle.com is offline
post #3 of 15 (permalink) Old 06-16-2014, 10:58 AM
I say forget the head work and just do the cams, adjustable pushrods and the lifters.
Running the stock heads will give you plenty torque with the right cam. You are going to spend around a $800 (x2 if work done by a shop) on the cam, pushrod, lifter upgrade and that is if you do the work yourself and that doesn't include a dyno tune and a tuner if you need one.
The dyno sheets on the fuelmoto web site shows a Woods TW222 on a stock 103 engine with a stage I intake and exhaust upgrades putting out 112 lbs of torque and around 94 or 95 HP. Torque is what you want HP is not what you're after.
You put a $1000 into heads and doing the work yourself (x2 if work done by a shop) you are going to pick up somewhere around 3 to 5 lbs of extra torque thats about $200 a lb of torque (not much bang for the buck). Look at some of the 103 stage IV build dynos sheets and in most cases the bikes are only putting out somewhere around 115 lb of torque.
I would just do the cam upgrades and get a good tune and ride the bike and see if that is what you want, If you want a bit more later on it isn't hard to swap out the heads. JMO
post #4 of 15 (permalink) Old 06-16-2014, 09:36 PM Thread Starter
Thumbs up
Thanks for the info. I am going to try to do the work myself. I do most of my own work. It doesn't look to hard. I can rent the tools I don't have. The woods 222 cam has been recommended to me before.
I have heard woods cams are noisey. That seems like too much money for the head work for what you get.
I have found shops that will do the Dyno's ranging from 250 to 500 bucks. Again you get what you pay for. Wish I knew which shop does the best DYNO.
It's great to be able to post here and get good opinions that are not motivated by money. JS
post #5 of 15 (permalink) Old 06-16-2014, 09:53 PM
Triplej's Avatar
There are 2 shops in the DFW area that you won't go wrong with them doing your Dyno work.
If in Dallas Ed at the Dyno Difference would be my choice.
http://www.thedynodifference.com/Home_Page.html
If you are in the Fort Worth area give GMR Performance a call
http://www.gmrperformance.com/
Another vote here for the 222 cams. Installed 3 sets for my bike and 2 other members and so far we are loving them. Holler if you need any of the tools.
Triplej is offline
post #6 of 15 (permalink) Old 06-17-2014, 12:57 AM Thread Starter
Thanks TripleJ , Info I needed. I live in Fort Worth. I've heard of GMR. Will get intouch with them they are close.
post #7 of 15 (permalink) Old 06-17-2014, 08:14 AM
Durwood's Avatar
The Andrews 57 is another viable option for a stage 2 103, as is the Tman 555 torqsters, there are a bunch of dyno sheets on HTT.
Pipe selection is critical for obtaining the curve you are looking for, Jamie at Fuel moto has some really nice, proven performers, Jack pot X pipe and a set of the 4.5 Pro touring mufflers makes an awesome combo.
But the most important part of the build is the tune, and both guys mentioned in Texas can get it done for you.
Good luck
Don't forget the tune.
Durwood is offline
post #8 of 15 (permalink) Old 06-17-2014, 11:03 AM
The only special tools you would need is the cam bearing puller and installation tools and they are pretty expensive.
What tuner are you running right now?
post #9 of 15 (permalink) Old 06-17-2014, 09:43 PM Thread Starter
Thanks for the info Scott. I'm very interested in the Andrews 48H Cam. Also need lifters, pushrods and gaskets.
post #10 of 15 (permalink) Old 06-17-2014, 09:52 PM Thread Starter
A list of up grades I have installed.
Stage 1 HD starburst Breather
SE Race Tuner
Fuel Moto Jackpot 2/1/2 Steel Plasma Ceramic coated header.
Vance and Hines High Output Slip on's
Heritage Bars
S&S lifters, FM pushrods and Rockouts Khaotic Engine Related 0 04-29-2017 08:38 PM
FS: SE Adjustable Pushrods and Woods Lifters JayKS Sold 2 02-19-2015 07:19 PM
Dragos 580 cams,woods lifters and FM adjustable pushrods. pat123 Parts for Sale 0 07-27-2014 02:26 PM
woods 222 cams, feuling lifters and fuel moto pushrods pat123 Sold 5 12-23-2013 07:51 PM
