Clutch slip advise? - Road Glide Forums
post #1 of 17 (permalink) Old 06-16-2014, 08:27 AM Thread Starter
Clutch slip advise?
Now that I have a few miles on the new cams I notice some clutch slip at the top of 3rd and 4th when I am really winding it up. Never did this before and I know its from the aditional power. What is the best fix for this? I assume the SE clutch spring is what most guys do to fix this?
Quickrunner is offline
post #2 of 17 (permalink) Old 06-16-2014, 08:39 AM
BDMastiff's Avatar
I would start by making sure your clutch is properly adjusted at the clutch pack. It's very easy to do yourself. Here's an instructional video.
https://www.youtube.com/watch?v=Zl92wwLiNwE
Also, the SE Clutch spring is always a good idea.
1996 Fatboy
BDMastiff is offline
post #3 of 17 (permalink) Old 06-16-2014, 08:44 AM
bikerdadmateo's Avatar
That happened to me when I adjusted clutch cable too tight. Loosened it up and it fixed the problem. I didn't do any cam change though
bikerdadmateo is offline
post #4 of 17 (permalink) Old 06-16-2014, 09:54 AM
I would add the heavy duty spring. It's like a $30 part and it's very easy to change.
2012 FLTRX
Sideways is offline
post #5 of 17 (permalink) Old 06-16-2014, 10:18 AM
I know when I did the 103 big bore kit in my 08 the big bore kit came with the SE clutch spring.
It would seem that when the MOCO went from the 96 engine to the 103 engine they would have put a stronger spring in the clutch. I would compare part #s on the stock clutch spring and the SE clutch spring before jumping into doing this upgrade.
I would think that just doing a cam upgrade would not be enough gain in torque to warrant a clutch spring upgrade. So make sure the clutch is adjusted correctly first.
Also when hitting the top of the rpm power range which in most cases it will be somewhere around 4500 rpm +/- and above the torque curve is going to start dropping off and the higher the rpm the more the torque curve will drop so don't confuse this with with a slipping clutch.
post #6 of 17 (permalink) Old 06-16-2014, 10:42 AM
The other thing to consider is if you are running synthetic in teh primary or regular oil. Synthetic has a tendency to cause clutch slippage. I had this issue on my built 95" dyna with heads and cams and regular oil in the primary. I put in the S/E spring and it was a thing of the past.
HogPro is offline
post #7 of 17 (permalink) Old 06-16-2014, 11:23 AM
FDR's RGC's Avatar
Change the spring
FDR's RGC is offline
post #8 of 17 (permalink) Old 06-16-2014, 11:35 AM
Trak350's Avatar
I changed my clutch spring and I run type F in my primary. I started with Barnetts HD spring (450lbs) and found the lever pull was just too tough for all day riding. I could do it but was just tired of it. I switched to the Barnett standard clutch spring (350lbs) and it seems to be getting the job done. The SE spring is about 380lbs. If you do decide to change the spring keep this in mind. Alot of posts on VPC and clutchwiz if you do decide to go heavier in the spring...
"Be polite, be professional, but have a plan to kill everybody you meet." Gen. James "Mad Dog" Mattis (USMC)
Trak350 is offline
post #9 of 17 (permalink) Old 06-16-2014, 04:48 PM
Hullhorr's Avatar
A little more expensive than a clutch spring, but the Variable Pressure Clutch (VPC) will also do the trick. The advantage to it verses the spring is it does not affect the clutch pull on your hand.
2009 FLTR MOP
Hullhorr is offline
post #10 of 17 (permalink) Old 06-16-2014, 04:56 PM
Bucktown's Avatar
Change the spring. Had the same issue with my 2012. No issues with the new SE spring
Bucktown is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 09:09 PM
Clutch Slip after cams Hack73 Troubleshooting for Road Glides 21 04-27-2017 11:44 AM
Advise on Slip-ons rookie racer Intake and Exhaust 23 05-23-2014 08:07 PM
Clutch Wiz vs Burley easy clutch Trak350 *General Road Glide Discussions/Pictures 14 03-11-2014 10:21 AM
I took your advise, I got a Windvest 12" RoadGlide5150 Windshields 7 06-21-2010 08:18 PM
