Engine stalling - Road Glide Forums
post #1 of 10 (permalink) Old 06-18-2014, 01:32 PM Thread Starter
Engine stalling
I have a 2012 fltrx, I recently installed thunderheader dragos 565 cams. After having it dyno tuned every now and then when i pull in clutch when coming to a stop the engine will die,it starts right back up. He spent about 7 hours tuning the bike and it runs great other than the stalling. Do you guys think this is a tuning issue or sensor issue like crank position sensor? thanks in advance for your replies.
jj8823 is offline
post #2 of 10 (permalink) Old 06-18-2014, 02:10 PM
pat123's Avatar
Check for codes.If it was sensor related you would have codes. If not take it back to the tuner.
pat123 is offline
post #3 of 10 (permalink) Old 06-18-2014, 02:41 PM Thread Starter
no codes, had it back already doesnt do it all the time.
jj8823 is offline
post #4 of 10 (permalink) Old 06-18-2014, 02:44 PM
What is the idle speed set at? May be it is to low.
post #5 of 10 (permalink) Old 06-18-2014, 02:53 PM Thread Starter
idle at startup is 1100 and after it warms up its 1000, i think the idle is ok
jj8823 is offline
post #6 of 10 (permalink) Old 06-18-2014, 05:39 PM
CooterB's Avatar
Just shooting from the hip here but I had sort of the same thing happen on my 06 about 1500 miles after new cams and pipes, and a custom map. Roll up to a stop sign and the bike would die, then start right back up? We chased the problem for a while until I figured out that it only did it when the fuel level was below 1/2 tank. Turns out I had a pin hole in the plastic line running between the fuel filter and the fuel pump. "The short line". Found this trying to figure out if the problem was fuel related. The fuel pump would "Hiss" when energized and when the fuel level was low, it would suck air, thus causing the stall. Never got any codes or engine light of any kind. I replaced the line with the pin hole in it and several thousand miles later I have not had any problems at all. Remove your gas cap and energize your fuel pump and listen for a hissing sound down in the tank. Make sure tank is low on fuel so the the line will be exposed above the fuel level. Worth a try. Good Luck!
06 Glide, 16" Wild One Chubbies, Barnett Cables, Fueling Reaper 525 Camchest with adjustable Push Rods, Bassani Pipes. PBR for fuel!!
CooterB is offline
post #7 of 10 (permalink) Old 06-18-2014, 06:12 PM Thread Starter
Thank cooter, fuel level doesnt seem to matter, but i will check. Thanks for the reply
jj8823 is offline
post #8 of 10 (permalink) Old 06-18-2014, 06:22 PM
pat123's Avatar
Did it do it before the tune?
pat123 is offline
post #9 of 10 (permalink) Old 06-18-2014, 06:24 PM
CooterB's Avatar
Good Luck. Hope it's a simple fix whatever it is!
CooterB is offline
post #10 of 10 (permalink) Old 06-18-2014, 06:41 PM Thread Starter
did not do it before tune, as much as i hate to pay for another shop to do another tune, probably what i will do.
jj8823 is offline
Engine Stalling connector ECM/Fuel Management systems 19 10-06-2018 07:36 PM
Engine bucking, stalling, high idle, sputtering Taccone *General Road Glide Discussions/Pictures 31 02-23-2018 10:34 PM
Need Advise- Stalling and Hesitating BDMastiff Troubleshooting for Road Glides 10 09-19-2010 08:20 PM
2000 Screaming Eagle Stalling Skycop26 Troubleshooting for Road Glides 0 09-13-2010 06:46 AM
07 stalling problem watchdog Troubleshooting for Road Glides 3 07-07-2010 11:37 AM
