Shifter Shalf - Road Glide Forums
post #1 of 7 (permalink) Old 06-20-2014, 07:27 AM Thread Starter
BigPoppi76's Avatar
Shifter Shalf
I have had to replace the shifter shaft and toe shifter arm....my question is should I use some type of grease or lubricant on the shaft? If so what is recommend?
Thanks for any replies!!
2003 Road Glide 120" Zipper Kit \ Baker 6 speed \ Rinehart "True Duals" \ Custom Paint \ A LOT of chrome
**Planned add-ons: TLC and polish, smoked light lens for turn signals and tail-light, and miles on the odometer**
BigPoppi76 is offline
post #2 of 7 (permalink) Old 06-20-2014, 07:37 AM
mocotom's Avatar
I use a very light coat of high temp anti-seize.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 7 (permalink) Old 06-20-2014, 08:34 AM
EasternSP's Avatar
Mine tends to shake around quite a bit so I use a heavy grease on mine. I think the excessive shaking is what causes the toe shifter to start stripping its teeth out.
Ken,
- 2006 RG 107/DD6/FatBagger 200mm Rear end w/Car tire
- 2016 RGU with Car Tire
EasternSP is offline
post #4 of 7 (permalink) Old 06-20-2014, 12:09 PM
JacktheBagger's Avatar
there used to be a grease fitting , never figgered why they removed it , the secret as well is to crank the bolt down real good on the toe shifter
JtB
2011 Ultra
JacktheBagger is offline
post #5 of 7 (permalink) Old 06-20-2014, 12:59 PM
sfcusaret2004's Avatar
try some of the famous dielectric grease, it seems to work for everything else and it'll cure any electrical problems you might encounter!
JK lol
sfcusaret2004 is offline
post #6 of 7 (permalink) Old 06-21-2014, 12:25 PM Thread Starter
BigPoppi76's Avatar
Thank you all for the feed back!!
post #7 of 7 (permalink) Old 06-22-2014, 12:57 PM
Triplej's Avatar
JtB
You can always roll yer own
Triplej is offline
2006 toe/heel shifter rdbateman Troubleshooting for Road Glides 8 11-24-2010 10:22 AM
Shifter Lever. mkoziol3 *General Road Glide Discussions/Pictures 0 11-15-2010 05:51 PM
Shifter Rod Change dklanecky Aftermarket Accessories 8 10-23-2010 10:33 AM
Heel/Toe Shifter DreamRider *General Road Glide Discussions/Pictures 6 06-01-2010 10:50 PM
Heim Joint shifter linkage Grillfish Troubleshooting for Road Glides 3 04-19-2010 06:08 PM
