measuring cam lift - Road Glide Forums
post #1 of 5 (permalink) Old 06-22-2014, 01:04 AM Thread Starter
jaysrgu's Avatar
measuring cam lift
how does one measure the cam lift when it is in the engine,without removing pushrods i am gonna guess a dial indicator onto of the rocker arm directly above the pushrod,then multiply that by the rocker ratio? any help would be greatly appreciated,thanks
jaysrgu is offline
post #2 of 5 (permalink) Old 06-22-2014, 07:42 AM
Banned
your a lot better off putting the indicator right on the lifter
PF120 is offline
post #3 of 5 (permalink) Old 06-23-2014, 06:12 AM
What cam/lift do you suspect you have?
Scott
Hillsidecycle.com is offline
post #4 of 5 (permalink) Old 06-23-2014, 07:25 PM Thread Starter
jaysrgu's Avatar
ill put it this way,i did a build and after having it dyno tuned there is a large difference in advertised power to real life power,the supplier now tells me the cam could have been mislabeled and i got the wrong one,so long story short i want to find the easiest way to measure lift,if pulling the prods and measuring the lift of the lifter i will do that,but was hoping i could measure rocker just for conveinyance.
jaysrgu is offline
post #5 of 5 (permalink) Old 06-25-2014, 10:21 PM
Thermodyne's Avatar
Advertised total lift would be measured at the valve.
If you have the lobe specs, then you can check maximum lift at the tappet.
If the motor is in the frame, checking the tappet would be the easy one. A little math would give you advertised lift.
If you don't have a dial indicator, you could do it with a vainer caliper. Wouldn't be quite as accurate, but should be close enough to verify the lift is as advertised.
If you want to check duration or valve timing, you're opening it up.
Thermodyne is offline
measuring tread depth shrtyonasprty Wheels and Tires 1 04-27-2017 02:40 PM
Measuring voltage out of amp to determine watts to speakers- help scottrgs Audio 5 04-03-2017 11:57 AM
Should I get a jack lift or a table type lift MarkL *General Road Glide Discussions/Pictures 32 04-01-2017 10:08 PM
To Lift Or Not to Lift Texas Rapier *General Road Glide Discussions/Pictures 6 05-30-2016 09:03 PM
HF 1000lb lift table lift Blackbag1 Do-IT-Yourself 44 06-11-2015 06:49 PM
