Andrews 57h or TW-222s - Road Glide Forums
post #1 of 15 (permalink) Old 06-23-2014, 07:37 PM Thread Starter
TYM2GLIDE's Avatar
So I have it down to 2, looking for a little help / nudge. I plan to leave the internal of my 103 stock (for now). I am looking for straight out of the box torque through the 5000 RPM. 2012 FLTRX 103.
Thanks,
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #2 of 15 (permalink) Old 06-23-2014, 08:01 PM
I really like the TW222 cams in my bike.
Do some research by looking at some dyno sheets that are running a similar build as yours
post #3 of 15 (permalink) Old 06-23-2014, 08:05 PM Thread Starter
TYM2GLIDE's Avatar
Thanks, I have researched to the utmost, I am leaning towards the 222s. I need to stop debating and order a set. Thanks for the input.
post #4 of 15 (permalink) Old 06-23-2014, 08:09 PM
I am torn between these cams as well. Are the tw222 worth the $160 price difference than the 57h?
[B]PV-Big Sucker-Rush Racing H-pipe-Big Louie's-Drago's 565 cams
Nightrain04 is offline
post #5 of 15 (permalink) Old 06-23-2014, 08:09 PM
RoadGlideGary's Avatar
+1 on the TW 222's. All around a sound choice, and supported by FM, which if you are looking for Tuner options will be well worth the investment.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #6 of 15 (permalink) Old 06-23-2014, 08:25 PM
Just because a cam is cheaper doesn't mean it will provide the performance that you are looking for. If you look at the specs the TW 222 will produce better low end torque.
post #7 of 15 (permalink) Old 06-23-2014, 08:53 PM
pat123's Avatar
I had the TW 222's in my street glide and my road glide. Great cam. A bit noisy. Due to the ramp on the cam lobes. Still a great cam. Take a look at the dragos 565 cam. There's a few dyno graphs in the dyno section.
pat123 is offline
post #8 of 15 (permalink) Old 06-23-2014, 09:56 PM
Turk05's Avatar
So far i really like my 222's in my 2011 FLTRU. Torque comes on strong from 2900 on up, but 3200 to 4k they will push you back in your seat... I think you will like them.
Turk05 is offline
post #9 of 15 (permalink) Old 06-24-2014, 06:30 AM
222's or Andrews 48's.
Both good producers in the low-mid.
Crane has a good one also, as does S&S.
On paper(dyno) you'll see a tiny difference, but seat of the pants, no.
Remember, there are NO magic cams, magic beans maybe, but no magic cams.
Scott
Hillsidecycle.com is offline
post #10 of 15 (permalink) Old 06-24-2014, 07:23 PM Thread Starter
TYM2GLIDE's Avatar
Hillsidecycle,
You mention the 48h, is there a reason you left out the 57h?
interested in your thoughts,
Thanks
Scott
Andrews 57H Cams-What pipes are you running? LM1976 Intake and Exhaust 7 05-11-2014 07:00 PM
Andrews 57H Installed PauleyB Engine Related 11 03-31-2014 07:37 PM
2011 FLTRX Andrews 57H vaughtcity Dyno Results 2 11-08-2013 11:24 AM
Andrews 57H cams ShitHouseRat Sold 6 09-11-2013 08:33 PM
Andrews 57H ShitHouseRat Engine Related 56 08-12-2013 09:29 PM
