Warning - Road Glide Forums
post #1 of 12 (permalink) Old 06-23-2014, 11:57 PM Thread Starter
Olskoo's Avatar
Warning
If anyone has read my postings about my 107 I had built 600 miles ago with seized pistons at 500 miles . That was not the only issue with this shop before that I had them put in a six speed and the damaged the trap door...after 35 days of waiting to get new piston and ju
Olskoo is offline
post #2 of 12 (permalink) Old 06-24-2014, 12:04 AM Thread Starter
Olskoo's Avatar
I sent before I was through any ways 35 day my bike sat waiting for new pistons and jugs (no hurry now) since it was on them they re used the rocker box gaskets and front and rear are leaking!! My bike isn't going back there for anything . Also have a friend who's paint was damaged there. You've been warned I wish I was. Shops name is BackRoads Custom Cycles in Lathrop Ca.
Olskoo is offline
post #3 of 12 (permalink) Old 06-24-2014, 12:13 AM
It sounds like a good time to get a new shop to bring your bike to for further work
post #4 of 12 (permalink) Old 06-24-2014, 03:10 AM
After they screwed up the trap door & your friends paint job, that should've been a sign, they aren't worth $hit. Good luck!
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #5 of 12 (permalink) Old 06-24-2014, 06:20 AM
Had a bike come in here that was at 2 dealers here in the CNY area.
They could not stop the leak behind the trans sprocket, and one even broke the main drive gear(!!??!!) attempting to do so.
One of those dealers did not install the quad seal behind the pulley spacer.........
It's repaired now.
Working at a dealership with a big toolbox, or reading/googling/you-tube info does NOT, repeat, does NOT, make one a mechanic.
No brag, but we've repaired others messed-up stuff on more times than I remember.
Scott
Hillsidecycle.com is offline
post #6 of 12 (permalink) Old 06-24-2014, 10:02 AM
Are you using a cast or a forged pistons?? In general a forge pistons needs a bit more break in time and the RPMs shouldn't go over 3500 in the first 500 miles. Some people may have different opinions on this but running a forged piston to hard before proper break in will seize the engine.
I have reused rocker box gaskets and rocker cover gaskets many times, sometime I reused the gaskets 4 or 5 times and never had leak issues. Not tightening the rocker boxes or rocker covers right or installing the gaskets wrong will cause leakage but in a lot of cases the upper O-Ring in the pushrod tubes will be the cause of leakage.
35 days is a bit too long to get parts IMO. Hope everything turns out good this time.
post #7 of 12 (permalink) Old 06-24-2014, 12:22 PM Thread Starter
Olskoo's Avatar
They are forged pistons and was told they did a dyno break in the first go around. This time I haven't went over 3500rpm and haven't ran the bike long with out letting it cool down , I've put 120 miles on it so far and it's going to a shop Saturday for new gaskets and seals. How many miles for a proper break in??
Olskoo is offline
post #8 of 12 (permalink) Old 06-24-2014, 12:32 PM Thread Starter
Olskoo's Avatar
Read back through IronMarks reply , got my answer. Thanks
Olskoo is offline
post #9 of 12 (permalink) Old 06-24-2014, 05:45 PM
Banned
you break in rings,not pistons.any seizing would be the result of setting the piston/cylinder wall clearance too tight.forged pistons need to be set looser than cast,but still has nothing to do with break in
PF120 is offline
post #10 of 12 (permalink) Old 06-24-2014, 05:49 PM
pat123's Avatar
X2
pat123 is offline
WARNING Clutch problem WARNING beatlesfab4fan *General Road Glide Discussions/Pictures 16 12-28-2015 01:08 PM
Daytona Warning Big_gary *General Road Glide Discussions/Pictures 9 03-04-2011 06:45 PM
Warning: Cute bull terrier puppies HUTMO *General Road Glide Discussions/Pictures 12 07-17-2010 09:13 PM
Hogtunes Warning. doc Do-IT-Yourself 10 06-29-2010 04:37 PM
Email Download Warning********** BillyBob Map Section 0 06-28-2010 01:52 PM
