New Dragula 2 pipe and Dragos 580 bolt in cams - Road Glide Forums
post #1 of 17 (permalink) Old 06-26-2014, 10:11 AM Thread Starter
Here is 2013 with New!!!!!!!
Dragos 580 cam bolt in
And our new test pipe Dragula 2 pipe coming soon only from Dragos Bike Works
SE tuner 5th gear pull.
Zipper max air flow large one.
Let me know what you think of pipe and how she looks naked.
Thanks FD
DragoBikeWorks is offline
post #2 of 17 (permalink) Old 06-26-2014, 10:27 AM
Q-Hog's Avatar
Looks streamlined and tucked in tight. Nice job.
Q-Hog is offline
post #3 of 17 (permalink) Old 06-26-2014, 10:28 AM
twistr's Avatar
Damn nice !! I was looking to order your scs-4 ( I prefer the rear header to be tucked in vs. the loop on the dragula)...but perhaps I'll order these dragulas...I guess they will be applicable to an '08 RG, correct?...I currently have Wood's TW6-6 cam and rinehart true-duals...I'm sure this exhaust will make me a happy camper.
Those numbers are very nice....I have spoken to you before frank and I can only say you have great customer service.
Riding Life's Twisting Roads...
On a 2008 Dark Blue Pearl Road Glide
twistr is offline
post #4 of 17 (permalink) Old 06-26-2014, 10:47 AM
connector's Avatar
Nice ...Having had the SC pipe since they came out a few years ago ,might be time for a new pipe
09 FLTR 103 Stage III
connector is offline
post #5 of 17 (permalink) Old 06-26-2014, 11:05 AM
EZMotoTim's Avatar
The pipe has a much better design. I'm burning my pants on the Dragula and have not been happy about it. Also, the mid-frame heat deflector has to be removed or modified with the Dragula. I'll be looking to change to the new design.
2017 FLTRXS, Givi V56 Topcase, Windvest 10", National Cycle Hand Deflectors, Rapid Transit Tank Bag. My last bike was 2014 Triumph Trophy SE. Before that: 2010 FLTRX.
EZMotoTim is offline
post #6 of 17 (permalink) Old 06-26-2014, 01:45 PM Thread Starter
The one thing you can expect from the new Dragula 2 is performance sound and quality it has what I call a double V bend.
It will also be longer and a whole new baffle design.
It will be tucked in more on rear head and front. This will help with exhaust flow and less restriction.
The was not changed for any heat issue.
The pipe will still have a 10 year warranty on construction. 2 Year on heat shields and muffler body.
Things that are different are......
Muffler body will be longer....
Less bends more tucked in what I call Double V bend.
Different baffle design will produce higher flow.
And you can get it with a 3.25 baffle in future.
Longer transition in internal core design in muffler and baffle body.
Still 16 gauge steel
Still will have 12mm 18mm 02 bungs
Still comes with top and bottom heat shields
Still comes with billet end cap tips
Still has 3 different baffles to chose from.
Still will have Ceramic coating inside and out 4mls thick total.
post #7 of 17 (permalink) Old 06-26-2014, 01:58 PM
Q-Hog's Avatar
Great list of improvements.
Q-Hog is offline
post #8 of 17 (permalink) Old 06-26-2014, 02:47 PM
Will the new header and shields be available separate from the muffler? Will my current Dracula muffler bolt up to it? Thanks.
Reddobe1 is offline
post #9 of 17 (permalink) Old 06-27-2014, 12:18 AM Thread Starter
Nothing will fit with new Dragula from old. Just tip.
post #10 of 17 (permalink) Old 06-27-2014, 06:37 AM
Z-SHARK's Avatar
Pipe looks like a great improvement Frank. Is it safe to say this pipe is a bit quieter with the larger baffle design?
Also.. How does the old Dragular compare to the new one numbers wise? Have you tested the same setup with both.
Fill with Gas... Twist throttle... Enjoy Life
Z-SHARK is offline
Dragula 2 and Dragos 580 bolt in cams DragoBikeWorks Dyno Results 7 03-27-2018 08:54 AM
'12 FLTRX - Dragos 1.5 heads, 580 cams, Dragula 2, .040 head gasket modot66 Dyno Results 8 08-21-2015 09:56 PM
Dragos 580 Cams and Dragula 2-1 rustyj671 Engine Related 3 03-17-2015 10:19 PM
